Milodon Dipstick tube question #221297
02/11/09 05:52 PM
02/11/09 05:52 PM
U.S.
moparniac Offline OP
U.S.
will this one work good... seems like the bottom of the tube is longer adn the mounting point is in a different location than stock ??? also I have a girdle.
Mopar Performance
Re: Milodon Dipstick tube question [Re: moparniac] #221298
02/11/09 10:28 PM
02/11/09 10:28 PM
U.S.
U.S.
Mopar Performance
Re: Milodon Dipstick tube question [Re: moparniac] #221299
02/11/09 10:54 PM
02/11/09 10:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Check the hole in the block to see if the girdle is blocking the oil dipstick tube I have had to modify all of the race aluminum oil pan rails to be able to use a stock oil dipstick tube
