The top one is commonly found on 2-bbl '80's 318s and 360s with 904. The carb rod is the giveaway that it's 2 bbl. Note the adjustment is made down on the trans rod. I don't know what year they started that setup; I'm guessing late 70's. I've pulled lots of them from Diplomats and 5th Avenues.
The second one is earlier, since the adjustment is made on the threaded rod to the carb. Dunno exact years, or whether 2 or 4 bbl, but I think that's a 2 bbl throttle bracket.
