70 RR tire size ?
#2206577
12/02/16 06:26 PM
12/02/16 06:26 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Need to pick up set of rallye rims and tires for 70 RR 15" What size do folks think look best? I know there was a thread here a while back but I cannot locate... what BSp?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR tire size ?
[Re: 71birdJ68]
#2206605
12/02/16 07:31 PM
12/02/16 07:31 PM
JMCFAN
New Mexico
Probably doing BFG Radial TAs
[Re: JMCFAN]
#2206606
12/02/16 07:41 PM
12/02/16 07:41 PM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
I like 235/60/15 on 7" rims front and 255/60/15 on 7" rims rear. If you go with 8" wide rear rims then the 275/60/15 is a nice look.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2206613
12/02/16 07:57 PM
12/02/16 07:57 PM
JMCFAN
New Mexico
Thanks! ANy particular back spacing ?
[Re: topside]
#2206658
12/02/16 09:30 PM
12/02/16 09:30 PM
JMCFAN
New Mexico
4.5" BS for anything up to & including 8" wide 15" wheel. Looks like the Wheel Vintiquies rims are 4.25 BS expect the 8" is 4.5.. Also... 7" brushed trim rings... ? Sorry... new to this..dumb ?'s
[Re: 70gtx440dana]
#2206661
12/02/16 09:31 PM
12/02/16 09:31 PM
JMCFAN
New Mexico
I like 235/60/15 on 7" rims front and 255/60/15 on 7" rims rear. If you go with 8" wide rear rims then the 275/60/15 is a nice look. Thanks! I like that idea!
[Re: JMCFAN]
#2206797
12/03/16 02:12 AM
12/03/16 02:12 AM
70gtx440dana
Lansing, MI
4.5" BS for anything up to & including 8" wide 15" wheel. Looks like the Wheel Vintiquies rims are 4.25 BS expect the 8" is 4.5.. Also... 7" brushed trim rings... ? Sorry... new to this..dumb ?'s You will not likely find 15" (7" wide or 8" wide rim) brushed trim rings in the aftermarket. Pretty sure most if not all are polished. Also, the paint finish on the aftermarket rims is not very close to original. I had mine painted in a more correct color.
[Re: 70gtx440dana]
#2206804
12/03/16 02:30 AM
12/03/16 02:30 AM
JMCFAN
New Mexico
4.5" BS for anything up to & including 8" wide 15" wheel. Looks like the Wheel Vintiquies rims are 4.25 BS expect the 8" is 4.5.. Also... 7" brushed trim rings... ? Sorry... new to this..dumb ?'s You will not likely find 15" (7" wide or 8" wide rim) brushed trim rings in the aftermarket. Pretty sure most if not all are polished. Also, the paint finish on the aftermarket rims is not very close to original. I had mine painted in a more correct color. Thanks! What about these..? https://www.wheelvintiques.com/accessories/trim-rings/7-o-e-m-brushed-chrysler-trim-ring.htmlAppreciate the help!! Hate to spend money and have to return...
[Re: Sxrxrnr]
#2206951
12/03/16 02:12 PM
12/03/16 02:12 PM
JMCFAN
New Mexico
How about Cooper Cobra? W
