Ram Eco Diesel Questions #2203970
11/28/16 07:16 PM
11/28/16 07:16 PM
Grand Rapids,Minnesota
65belvedere Offline OP
I am thinking about buying a 2016 RAM Eco Diesel.I could use some real world opinions about reliability, towing and real fuel
mileage. Thanks
Re: Ram Eco Diesel Questions [Re: 65belvedere] #2203986
11/28/16 07:36 PM
11/28/16 07:36 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
I have a 2015 Ecodiesel 4 wd crew cab Big Horn 4wd with Ram Boxes
Mixed driving yields 23 mpg over the roughly 25k miles I have driven it. It has a tow package but I have not towed with it yet. I have seen others go 900 Miles on one tank of diesel.
payload capacity is quite limited once you load it with options. I believe my max payload is 1050# and that includes passengers. With 600# of tongue weight that leaves little for me my family and gear.
Here is the best forum I have found.
http://www.ram1500diesel.com/forum/ram-1500-ecodiesel-forum/
A number of people have blown up their motors but I have had no issues. Plus it seems like people with issues tend to post on forums. People have been quoted 30k for a new motor by a dealership.
There have also been numbers of water/oil cooler failures which fill the cooling system with oil.
The oil changes used to be brutal with a 10.5 quart change, 60$ filter and Eurospec diesel oil but they changed the oil spec to Rotella T6 which is less expensive.
2017 Production may not have started based on EPA wanting to re-certify most small replacement diesel.
The mileage drop off from 3:55 to 3:91 appears to be minimal so I would strongly consider the 3:91 if you will be towing.
Any other questions ask away!
Thank you!
Kevin
Re: Ram Eco Diesel Questions [Re: 65belvedere] #2204357
11/29/16 12:08 PM
11/29/16 12:08 PM
E
earlymopar Offline
earlymopar  Offline
E
I have a 2016 quad cab Eco Diesel and pull a 23' trailer with 6100 lb dry weight. The truck not only does very well pulling, it continues to deliver great mileage even though I haven't verified the numbers while pulling. The brakes are incredible. Between the "Towing / Hauling" button that changes shift points and the 8-speed automatic, I can't speak highly enough of my truck. I also opted for the "trailer package" which came with the pivoting trailer mirrors (very nice), integrated trailer brake controller, Class 1V hitch and lower rear-end gears.
- EM
Re: Ram Eco Diesel Questions [Re: 65belvedere] #2204379
11/29/16 12:58 PM
11/29/16 12:58 PM
E
earlymopar Offline
earlymopar  Offline
E
I forgot to mention that mine is a 2WD. I didn't want 4WD and didn't want the added weight and gear drag.
- EM
Re: Ram Eco Diesel Questions [Re: earlymopar] #2205014
11/30/16 02:49 AM
11/30/16 02:49 AM
Thanks guys for the info. I'll check out that website.
