4.7l engine swap #2203370
11/27/16 04:15 PM
11/27/16 04:15 PM
colorado
bdub Offline OP
bdub  Offline OP
colorado
I am swapping out my 2000 4.7l dakota 4x4 engine, and I've sent core back so I have no comparison. On the new long block there is a threaded hole,on top of the block (about 12mm) in the center of the front of the block between the plastic throttle body assembly and the timing cover. I don't know what goes there! I'm at the point of dropping the engine in so any help would be greatly appreciated! Thanks Bdub!
Re: 4.7l engine swap [Re: bdub] #2203413
11/27/16 06:01 PM
11/27/16 06:01 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
how about a picture??
Re: 4.7l engine swap [Re: rumblebee4232] #2203462
11/27/16 07:42 PM
11/27/16 07:42 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
I just looked at my 2006 4.7 not sure if they are the same.
But a brass sensor with a 2 wire plug on top. brown/orange and black/green wires. Water Temp sensor?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 4.7l engine swap [Re: Stroker Scamp] #2203632
11/28/16 12:06 AM
11/28/16 12:06 AM
GEORGIA
barracuda7199 Offline
GEORGIA
iagree sounds like the temp sensor hole. Pic would confirm it
