Any experience with M&H FRONT drag radial? 26" x 15"
#2201245
11/23/16 03:31 PM
11/23/16 03:31 PM
BradH
My 215/75R15 passenger car tires should probably be replaced before my car hits the asphalt again. I just looked at the M&H 26" x 15" DOT radial and thought it might be a good replacement, plus it would lower the front of the car a tad. It sits pretty much level with the current tire sizes, suspension setup, etc.
Re: Any experience with M&H FRONT drag radial? 26" x 15"
[Re: Jeremiah]
#2201345
11/23/16 06:34 PM
11/23/16 06:34 PM
BradH
It would be a lot more bad-ass if it wasn't a dust-covered pile of parts spread across my garage & basement.
The picture makes it look nicer than it is, but it's been mine since 1995 and has always been more of a car to hammer on than wash & wax. It is (was) a 10-second 20-footer... not likely to get any better in the looks department since the $ I spend on it is always on making it faster... or fixing it.
[Re: BradH]
#2201490
11/23/16 11:01 PM
11/23/16 11:01 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Brad they drive a lot nicer then bias ply front runners on the street. For me they acted like a little taller tire staging, because of the radial tire squish.
They do weigh a little more, and they want a little wider wheel from what I saw. I still have mine for when I want to drive the car around
"Just a Bracket car dressed up like a streetcar"
[Re: BradH]
#2201600
11/24/16 01:13 AM
11/24/16 01:13 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
The picture makes it look nicer than it is, but it's been mine since 1995 and has always been more of a car to hammer on than wash & wax. It is (was) a 10-second 20-footer... not likely to get any better in the looks department since the $ I spend on it is always on making it faster... or fixing it. I hear you on that, my red charger is a grayish-white from metal/fiberglass dust. All of these cars were meant to be pounded on, that's what makes them cool. This is coming from a guy with a half mile long gravel driveway lol it makes me want to cry. My friend that helps me with body work and paint says the paint is wearing off of my cars one trip at a time. Whatever, they are meant to be driven. Again, nice looking car it would be cool to see more pictures of it inside and out.
[Re: Just-a-dart]
#2201647
11/24/16 03:13 AM
11/24/16 03:13 AM
BradH
They do weigh a little more, and they want a little wider wheel from what I saw. I still have mine for when I want to drive the car around At one point my front street tires were Moroso Drag Specials, for what that's worth. I have 5" wheels, and I see different recommendations for widths depending on whose listing I read. I'd expect a 5" would be fine, although some said it needed 4" rims... which I sold with those Morosos I used to run.
[Re: SILVER67]
#2201649
11/24/16 03:19 AM
11/24/16 03:19 AM
BradH
I called them directly...they said it's basically meant for track only use. Any major amount of street driving and it'll wear quickly and and decrease it's life overall. Is rated at over 1300# however. Mike That's odd, especially since they push their Drag Radial series as dual-purpose tires. The MoPig is far from a daily driver (when it is running...), so they still sound reasonable for my intended use.
[Re: SILVER67]
#2201795
11/24/16 01:43 PM
11/24/16 01:43 PM
Just-a-dart
Glendora Ca.
I called them directly...they said it's basically meant for track only use. Any major amount of street driving and it'll wear quickly and and decrease it's life overall. Is rated at over 1300# however. Mike They are not 50,000 mile tires. For a lot of the guys on this site rot is the problem not wear.
[Re: Just-a-dart]
#2258705
02/24/17 02:14 PM
02/24/17 02:14 PM
BradH
Back from the dead! After looking at both the M/T S/R 26x6.00R15 and the M&H 185/75R15, I'd prefer the M&H, if for no other reason than the M/T tire is really much closer to 25" tall. That's shorter than I want to run with a legit 28" tire on the back. The M&H also has a much higher load rating at the same 35 PSI pressure (1320 vs 990), which should be better suited to my BB E-body that's no lightweight. Any final(?) or updated comments on the M&H front radials would be appreciated before I pull out the Visa card.
[Re: BradH]
#2258877
02/24/17 07:06 PM
02/24/17 07:06 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
got a set of the MT 28x6"fronts in my shop yesterday . Going on a 3900lb 62 Belair . They are LT , truck , rated . I think that means slightly different build requirements compared to passenger , not just load rating Nice flame tread , must be faster . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2259157
02/25/17 11:41 AM
02/25/17 11:41 AM
BradH
got a set of the MT 28x6"fronts in my shop yesterday . Any idea how tall they really are vs the advertised specs? The "26" sure isn't what is specified to be, so I'm curious if the "28" is also undersized.
[Re: BradH]
#2259431
02/25/17 08:15 PM
02/25/17 08:15 PM
Posts: 1,505 TN
SCATPACK 1
TN
Back from the dead! After looking at both the M/T S/R 26x6.00R15 and the M&H 185/75R15, I'd prefer the M&H, if for no other reason than the M/T tire is really much closer to 25" tall. That's shorter than I want to run with a legit 28" tire on the back. The M&H also has a much higher load rating at the same 35 PSI pressure (1320 vs 990), which should be better suited to my BB E-body that's no lightweight. Any final(?) or updated comments on the M&H front radials would be appreciated before I pull out the Visa card. That picture of an M&H tire looks a lot better for street strip than this Hoosier front
Old Geezer Racing
[Re: Just-a-dart]
#2259651
02/26/17 05:19 AM
02/26/17 05:19 AM
Just-a-dart
Glendora Ca.
I called them directly...they said it's basically meant for track only use. Any major amount of street driving and it'll wear quickly and and decrease it's life overall. Is rated at over 1300# however. Mike They are not 50,000 mile tires. For a lot of the guys on this site rot is the problem not wear. Brad you will like them.They are on the car in my sig picture. Hit the buy now button and worry about something else.
[Re: Just-a-dart]
#2259703
02/26/17 11:50 AM
02/26/17 11:50 AM
BradH
I called them directly...they said it's basically meant for track only use. Any major amount of street driving and it'll wear quickly and and decrease it's life overall. Is rated at over 1300# however. Mike They are not 50,000 mile tires. For a lot of the guys on this site rot is the problem not wear. Brad you will like them.They are on the car in my sig picture. Hit the buy now button and worry about something else. &
[Re: BradH]
#2259825
02/26/17 02:40 PM
02/26/17 02:40 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
After looking at both the M/T S/R 26x6.00R15 and the M&H 185/75R15, I'd prefer the M&H, if for no other reason than the M/T tire is really much closer to 25" tall. That's shorter than I want to run with a legit 28" tire on the back. I was afraid to buy the M/T #6652 because I was also told it was less than 26" tall but I bought them and I was very happy to see they were about 26.25" tall mounted on my 4" wide rims. I'm extremely happy with the way they look and drive.
[Re: ProSport]
#2259878
02/26/17 03:29 PM
02/26/17 03:29 PM
BradH
After looking at both the M/T S/R 26x6.00R15 and the M&H 185/75R15, I'd prefer the M&H, if for no other reason than the M/T tire is really much closer to 25" tall. That's shorter than I want to run with a legit 28" tire on the back. I was afraid to buy the M/T #6652 because I was also told it was less than 26" tall but I bought them and I was very happy to see they were about 26.25" tall mounted on my 4" wide rims. I'm extremely happy with the way they look and drive. Bob, I saw your YB thread on the M/T 6652 from some time back where people were saying they were more like 2 5.25", not 2 6.25"? That particular thread is part of what steered me away (no pun intended... although it's a good one ) from the M/T. ////////////////// It's a moot point now. I've got a pair of the M&Hs, along w/ a few other items, coming from Jeg's this week.
[Re: BradH]
#2260006
02/26/17 06:49 PM
02/26/17 06:49 PM
Posts: 4,457 Washington
madscientist
Washington
Cool. I've never used an M&H tire I didn't like. I bought my first pair in 1982.
[Re: BradH]
#2260680
02/27/17 08:46 PM
02/27/17 08:46 PM
tex013
Sydney,Australia
Brad Couple of shots of MT tyre . This is a 28x6 on a 5" rime
Tex
