Re: FI Tech fuel injection fuel lines
[Re: CSK]
#2201172
11/23/16 01:25 PM
11/23/16 01:25 PM
Posts: 4,811 Star Idaho
67vertman
Star Idaho
This is the setup I am running on my EFI system. I am running F&B 6 pac with 500 hp. No issues.
My Monster are real!
Living within your means makes life pretty easy.
[Re: fastmark]
#2201326
11/23/16 05:54 PM
11/23/16 05:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The regulator will control the flow as long as the supply and/or return lines are not too small. So if you are thinking one day you might step it up consider upsizing the lines since you are buying new anyway, assuming the cost increase isn't too stupid.
[Re: fastmark]
#2201385
11/23/16 07:30 PM
11/23/16 07:30 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FI Tech specifies a #6 (3/8") return line.
[Re: John_Kunkel]
#2201399
11/23/16 08:06 PM
11/23/16 08:06 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
This is the proper thing to do. Remember that you'll be returning a pretty good volume of fuel (far more than you consume outside of WOT). Pushing that much volume through a 1/4" line means more pressure and velocity are required to get the job done. That tiny return is like putting your thumb over the end of a water hose. Pressure is going to build up. The pump will be working hard instead of idling with a large return line.
[Re: fastmark]
#2201668
11/24/16 05:16 AM
11/24/16 05:16 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I was reading the software setup manual, and the "Go EFI" units have a Pulse Width Modulated fuel pump driver, but it looks like it does not monitor the fuel pressure, it looks a user pre-set TPS and RPM values, that if the engine is under the specified RPM or TPS value, then the pump drivers applies a user defined PWM percentage to set the pump for a lower flow rate.
On my Coronet (Edelbrock XT EFI), I am running -6 AN hose supply and return, except for about 6" to/from the Spectra EFI fuel tank that uses 3/8" supply and 5/16" return. It only has a 225 LPH pump, but I think the line sizes would be fine even with a larger pump.
Also, they have a $100 rebate going on for the FiTech units
[Re: thehemikid]
#2202291
11/25/16 01:03 PM
11/25/16 01:03 PM
feets
Senior Management
Senior Management
Irving, TX
After a quick call to FITech to be sure that wasn't intentional I'd slam that thing in a collet and poke a bigger hole through it.
[Re: fastmark]
#2202354
11/25/16 02:43 PM
11/25/16 02:43 PM
Supercuda
About to go away
About to go away
up yours
It's my understanding that -6AN is supposed to be 3/8" internal diameter which is .375". Not even sure you can drill that return fitting that big. What you have is barely bigger than 3/16", or -3AN.
[Re: fastmark]
#2202384
11/25/16 03:24 PM
11/25/16 03:24 PM
Supercuda
About to go away
About to go away
up yours
All math aside, it's described as -6 AN, which to actually be a -6 needs a 3/8" passage.
Does it need 3/8"? I dunno, don't care as long as it works.
[Re: Supercuda]
#2202412
11/25/16 04:20 PM
11/25/16 04:20 PM
John_Kunkel
Rio Linda, CA
The nominal dimension for a common #6 AN fitting is .295".
Whenever a manufacturer specifies a certain line/hose size they are taking into consideration the fitting bore size, especially if they supply the fitting.
[Re: John_Kunkel]
#2202468
11/25/16 05:40 PM
11/25/16 05:40 PM
Posts: 1,013 near Kansas City
igozumn
near Kansas City
I had emailed Fitech about this situation back in December/January, not sure, and they said the 5/16 return would be fine. So, I went with it and yanked the original 1/4 return. Put a new 3/8 supply line and used the original 5/16 supply as the new return. Haven't experienced any issues that would indicate an issue with the return's size. Edit: Maybe they have changed their "tune", since then? That being said, I noticed one day, many months ago, that I thought the tank was warmer than maybe it should, but haven't dealt with it, nor asked around as to what others are experiencing. Also, in putting together my system, I did find some fittings from various manufacturers, seemed to be a bit smaller than what I thought I was getting. I made sure that if I was running a 5/16 return or 3/8 supply, that it was actually 5/16 or 3/8 (or as close as could be within reason) all the way from the pump to the Fitech.
