Re: help with an axle cover i saw at the 16 NATS
[Re: Stanton]
#2200815
11/22/16 10:14 PM
11/22/16 10:14 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
What did they bolt to? The wheel studs? It sounds a little like ... Moon Discs.
[Re: mcat4321]
#2200855
11/22/16 11:11 PM
11/22/16 11:11 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
It sounds like you are describing NASCAR style floating hub axles. This means the cover you describe comes off and the axle is splined on both ends and the hub is splined and has bearings like the front wheels do. Google floating hubs for stock cars and you will probably see what you want. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
