590 big block cam #2197352
11/16/16 02:53 PM
11/16/16 02:53 PM
florida usa
moparmarkk Offline OP
florida usa
Hi,does any body have a cam card for a mopar 590 big block cam?Looking for spring recommendations and spring height,thanks mark
Re: 590 big block cam [Re: moparmarkk] #2197369
11/16/16 03:42 PM
11/16/16 03:42 PM
Ma suggested the P2806077 spring. for height I'd mockup & see if you have at least .060" clearance between the coils before coil bind. 312/312 adv dur. 104 overlap. 106 cl and 28/32 on the lash but reportedly going less is beneficial. 3400-6900 basic RPM range. drag super comp. 590/590" lift
Re: 590 big block cam [Re: moparmarkk] #2197523
11/16/16 08:04 PM
11/16/16 08:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO....... The 077 spring is one of the worst springs ever.
Not enough seat pressure, way too much open pressure.
I actually refuse to put them on customers heads when they have shown up with them.
The 590 cam works well with 145-165 on the seat, 375-425 open, depending on what rocker ratio you'll be running and how high you plan to rev it.
For 1.5 rockers and 7000-ish rpm the Isky 8005-a installed at 1.860 is a good choice.
Re: 590 big block cam [Re: fast68plymouth] #2197994
11/17/16 03:20 PM
11/17/16 03:20 PM
florida usa
florida usa
thanks for the info guy's
Re: 590 big block cam [Re: moparmarkk] #2198143
11/17/16 07:57 PM
11/17/16 07:57 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The Isky 8005 A is the spring I use with them like Mr Porter said.
It also likes to be advanced a couple degrees if you have the PTV clearance.
Todd
Re: 590 big block cam [Re: sasquatch] #2198538
11/18/16 04:04 PM
11/18/16 04:04 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Amazon has a pretty good price(167.43) on 'em right now...
https://www.amazon.com/Isky-Racing-Cams-8005-Spring/dp/B002VVZ0CE
