Issues with MSD 6al digital #2183986
10/27/16 07:00 PM
10/27/16 07:00 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I'm installing a 6AL for a friend on his Roadrunner.
We're using the Mopar electronic distributor to trigger it.
I couldn't get it to fire initially so I did the green to purple jumper with the key on. It worked fine right off the box. I then tried to jump the leads on the pigtail right next to the distributor. Very intermittent. It simply would not spark but about 1/3 of the time. I replaced that segment the of wiring and it seemed to trigger better. Pulled the distributor out and it seems to trigger if you spin the shaft at higher RPM but not slowly. I did check a couple of pickups to make sure that wasn't the problem and checked the gap.
Is the box the issue?!
Positive side feeding the box is directly off the battery and the negative side is too.
Re: Issues with MSD 6al digital [Re: GY3] #2184004
10/27/16 07:23 PM
10/27/16 07:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
turn on lead for the msd gets 12v during crank and run from the ignition?
Re: Issues with MSD 6al digital [Re: krautrock] #2184008
10/27/16 07:33 PM
10/27/16 07:33 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes.
Re: Issues with MSD 6al digital [Re: GY3] #2184017
10/27/16 07:55 PM
10/27/16 07:55 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i had a problem in my coronet when i put a 6al in, it would barely fire off when i let off the key from start. it was ign1 or 2, i forget.
turns out the wire that i was using didn't get voltage in start, only run. i had to tie the ign1 and ign2 wires together to feed the msd turn on power. give that a try.
i was working at the bulkhead, since much of my stuff was butchered...
Re: Issues with MSD 6al digital [Re: GY3] #2184031
10/27/16 08:14 PM
10/27/16 08:14 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
The blue wire goes dead during cranking unless you have the stock ballast resistor in place and a factory, functional ballast resistor bypass wire connected to the stock starter relay.
twocents
Re: Issues with MSD 6al digital [Re: @#$%&*!] #2184040
10/27/16 08:19 PM
10/27/16 08:19 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
twocents
Ballast was in place but I bypassed temporarily with jumper wire.
Re: Issues with MSD 6al digital [Re: GY3] #2184057
10/27/16 08:45 PM
10/27/16 08:45 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
You'd still need the wire from the starter relay to the coil side of the ballast resistor. It's easy to put a test light or voltmeter on the wire and see if there's voltage while cranking.
Re: Issues with MSD 6al digital [Re: @#$%&*!] #2184259
10/28/16 12:08 AM
10/28/16 12:08 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Again, I haven't gotten to cranking yet. How would the switched power lead to spark being okay at the box but intermittent at the pickup?
I have it wired exactly the same as my '63 and it works perfectly and fires instantly!
Re: Issues with MSD 6al digital [Re: GY3] #2184422
10/28/16 11:48 AM
10/28/16 11:48 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The blue wire the connects to the coil positive has power when the switch is on both start and run... IMO you have it wired correctly
Re: Issues with MSD 6al digital [Re: GTX MATT] #2184483
10/28/16 01:10 PM
10/28/16 01:10 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Exactly! That's the way it is on my car and even in the MSD diagram. It DOES have spark to the distributor. You spin it by hand at higher RPM and it's fine. At cranking speeds, though, it doesn't spark.
I'm beginning to think it's a bad box...
Re: Issues with MSD 6al digital [Re: GY3] #2184524
10/28/16 02:11 PM
10/28/16 02:11 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
so you have voltage during crank and run.
the car won't run?
or the problem is your are not getting spark when spinning the dist slowly?
Re: Issues with MSD 6al digital [Re: GY3] #2184527
10/28/16 02:14 PM
10/28/16 02:14 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I installed 3 6AL boxes with a Mopar electronic distributor, blew all three, spoke to MSD, they said they were compatible. They would work for about 10 seconds, than die.
Installed the old MSD unit, worked fine.
Installed a new MSD distributer with a new 6AL box, no other changes, still working. I took one of the boxes apart, it had a burnt out quad driver in it.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Issues with MSD 6al digital [Re: GY3] #2184553
10/28/16 02:53 PM
10/28/16 02:53 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
about two years ago i put an msd streetfire on my powerwagon, factory electronic dist, haven't had any problems at all.
Re: Issues with MSD 6al digital [Re: krautrock] #2196951
11/15/16 09:23 PM
11/15/16 09:23 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
An update on this. My friend ordered an old style analog MSD 6AL off of Ebay and I installed it today. It fired up on the first twist of the key! flame
Nothing like wasting an entire day working on something only to find out the brand new box was trash!
'63 Dodge 330
11.19 @ 121 mph
Re: Issues with MSD 6al digital [Re: GY3] #2197020
11/15/16 10:43 PM
11/15/16 10:43 PM
Washington
madscientist Offline
Washington
So analog isn't always bad.
Re: Issues with MSD 6al digital [Re: madscientist] #2197028
11/15/16 10:55 PM
11/15/16 10:55 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I've been hearing bad things about MSD here lately but didn't want to believe them...
The MSD tech was worthless and pretty much decided not to help with anything after he found out I was hooking the box up to something other than an MSD distributor. It's a magnetic pickup distributor for chrissakes!
Time to start hoarding the old stuff...
'63 Dodge 330
11.19 @ 121 mph
Re: Issues with MSD 6al digital [Re: GY3] #2197030
11/15/16 10:57 PM
11/15/16 10:57 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and hence the reason I'm still using the old school box. Sure like some of the features of the new digi stuff though.
Re: Issues with MSD 6al digital [Re: J_BODY] #2197037
11/15/16 11:02 PM
11/15/16 11:02 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Exactly!
They almost had me convinced to upgrade mine a few months ago.
Not now!
Re: Issues with MSD 6al digital [Re: GY3] #2197068
11/15/16 11:58 PM
11/15/16 11:58 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run a MSD digital 6 box and it has worked perfect for the last 5 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Issues with MSD 6al digital [Re: GY3] #2197155
11/16/16 01:35 AM
11/16/16 01:35 AM
Washington
Washington
I'm already well into the hoarding process.
