2000 Dakota frame swap? #219659
02/10/09 12:04 AM
02/10/09 12:04 AM
Upstate, NY
sixpack4spd Offline OP
Upstate, NY
I found a decent V8 5spd Dakota that I was thinking of using under a 47 Dodge pickup. Does this still work with the newer trucks? Are they wider than the earlier Dakota trucks?
Re: 2000 Dakota frame swap? [Re: sixpack4spd] #219660
02/10/09 01:29 AM
02/10/09 01:29 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the width is the same as the older Dakotas, but they are a bit wide for a 47 pickup. Think Ron may have pictures of one he has done, or almost done. There was a 47 posted over on the HAMB board mounted on a late model Dakota chassis, think it has also been posted here too, look back through previous posts. Gene
Re: 2000 Dakota frame swap? [Re: poorboy] #219661
02/10/09 12:13 PM
02/10/09 12:13 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Anybody got a link to the second truck?
Re: 2000 Dakota frame swap? [Re: Flipper1938] #219662
02/10/09 01:06 PM
02/10/09 01:06 PM
Upstate, NY
Upstate, NY
My concern is that most swaps seem to be using the older Dakota frames. The Dakota's seem to get bigger every time a new style comes out.
Re: 2000 Dakota frame swap? [Re: sixpack4spd] #219663
02/10/09 01:11 PM
02/10/09 01:11 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
that may be true but if your not afraid of a little more work, its pretty easy to make the fenders a little wider, just add 2-4" where the fender meets the grill area and add the same amount where the fender meets the body Ron....
