Your experiences with Optima/Odyssey/AGM lifespans? #2190561
11/06/16 10:53 AM
11/06/16 10:53 AM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
What are your good or bad experiences with
non-conventional lead acid battery designs,
particularly in
useable lifespan of the battery
versus buying price?
The spiral internals of the Optima look interesting,
but some reviewers report that they fail soon after the 2 year warranty is up?
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190565
11/06/16 11:00 AM
11/06/16 11:00 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
the classic case AGM battery in my 72 roadrunner lasted 15 years before it wouldn't hold a charge properly.
never used a battery tender on it. stored it inside my house during winter storage. springtime i gave it a charge, with a charger designed for AGM battery, before installing it.
perception is 90% of reality
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190575
11/06/16 11:12 AM
11/06/16 11:12 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My original Optima was an awesome piece that lasted 12 years.
The Optima in my truck is 5 or more years old and I'm starting to question its reliability. The truck is rarely driven but has been turning a tiny bit slower when I try to start it.
I, too, have heard some bad rumblings about recent production batteries not lasting that long. The rumor is that they offshored production and used recycled materials that aren't up to snuff.
I can't confirm that.
I can tell you that 3 years is the average service life out of a car battery in north Texas.
- Stu Harmon
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190592
11/06/16 11:31 AM
11/06/16 11:31 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I had a red top Optima for 10 plus years until my charging system recently started to overcharge and ruined it. Honestly the car sat for long periods and I never really kept it charged like I should have but it still ran strong. I replaced it with another rep top. So far so good.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190596
11/06/16 11:38 AM
11/06/16 11:38 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My experience has been they last a long time. Last one I killed lasted 13 years. I have also learned I don't car for them in a race car that requires charging. The reserve capacity isn't great enough. They don't regain a lot of capacity unless slow charged. Therefore if you run a small alternator and big power draw they didn't like to go more than a few days of racing with out a slow charge. That made 3 day and some 2 day events tough unless you could plug in the charger or run the generator over night.
Doug
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190690
11/06/16 01:49 PM
11/06/16 01:49 PM
Mr T2U Offline
Mr T2U  Offline
one thing to remember about AGM battery is proper charging.
a regular battery charger won't charge them without a special process.
you ether attach a good battery to the AGM one with good jumper cables. then hook the charger to it or use a charger designed for them.
special AGM chargers have dropped in the last few years. getting the proper one is reccomended.
also if you have a low battery in your car the alternator might not charge it properly.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190802
11/06/16 05:08 PM
11/06/16 05:08 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I've had Optima yellow and red tops all work great for years. I was completely satisfied with paying a little higher price for them.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190851
11/06/16 06:57 PM
11/06/16 06:57 PM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Any experiences with the Blue Top Optimas?
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190882
11/06/16 07:44 PM
11/06/16 07:44 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I had those in my boat as well, lasted all the 8 years that I owned it. It was a v-drive that got very little use.
[img]https://scontent-dft4-1.xx.fbcdn.net/v/t...amp;oe=588B1D1F[/img]
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2190884
11/06/16 07:48 PM
11/06/16 07:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I got almost 10 years out of one, 7 so far on another.
I usually get 5-7 years out of any battery - except ones I bought from WalMart, those either leaked or died within a year - as I put trickle chargers on them, but I use the Optimas for cars where I want no chance of any damage from terminal corrosion or acid.
Schumacher has a trickle charger that also works on AGM, and I saw the other day that Duralast (AutoZone) also sells one. Usually around $28.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2191203
11/07/16 03:25 AM
11/07/16 03:25 AM
Iowa
dsp Offline
dsp  Offline
Iowa
I still have the very first AGM battery I purchased - it's now 16 years old! I've also installed a few Die Hard Platinum (Odyssey?) batteries in family members cars. I'm bummed that Sears quit selling the Die Hard Platinum. AGM batteries do require a special charger.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: Mr T2U] #2191210
11/07/16 04:25 AM
11/07/16 04:25 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I got 13 months out of mine purchased in 2012.
"I think its got a hemi"
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2191765
11/07/16 09:30 PM
11/07/16 09:30 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Im on my second one of these beauties after 10 years...
1MYTGTX
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2191858
11/07/16 11:25 PM
11/07/16 11:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
12 years on a red top Optima. I let it go with the truck when I traded it in,and so far the new owner still is using it.
Nautilus Racing-
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2192089
11/08/16 11:50 AM
11/08/16 11:50 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Anyone have experience with the Exide built AGM batteries?
Notice their graphs
http://www.exide.com/Media/files/Downloads/TransAmer/Products/Edge6pgMKTG27830_8-14.pdf
The local Rural King store stocks these
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 1MYTGTX] #2193442
11/09/16 09:00 PM
11/09/16 09:00 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I have the same lightweight (26 pounds) battery on my 11.5 to 1 451 since 8 years...
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2193468
11/09/16 09:37 PM
11/09/16 09:37 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Notice their graphs
EVery time I had a problem battery it was an Exide...
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: minivan] #2193493
11/09/16 10:04 PM
11/09/16 10:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Notice their graphs
I've been looking at one of those for the Imperial.
It just so happens that we replaced one at work. I saw it in the core pile and the date on the battery was March 2016. I pulled it and took it home. If I can get it to take a charge I'll bring my old battery in as a core.
It had 11.7 volts on it when I put the intelligent charger on it last night. The battery went up to 13.1 volts before I took it off the charger and was at 13.0 when I left this morning.
I'll check it when I get home to see if it's still holding 13 volts.
- Stu Harmon
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: feets] #2193518
11/09/16 10:25 PM
11/09/16 10:25 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Worse one was a brand new battery in my freshly restored 77 stepside.. I kept on having voltage and low battery problems and the battery checked out good every time..
The Battery sales guy finally pulled the battery and checked each cell with a "float"? tester.. Had a bad cell...
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2193852
11/10/16 12:17 PM
11/10/16 12:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'm waiting for my new adopted AGM battery to stabilize at 12.5 volts without a load on it. It's still a bit high at 12.9 volts.
So far, I think it's a good battery. I'll let it sit until Saturday when I can drop it in the truck and chase down the draw that is killing the current battery.
- Stu Harmon
