Re: Stock 8.75" rear axle shafts - worth upgrading?
[Re: GoodysGotaCuda]
#2190833
11/06/16 06:17 PM
11/06/16 06:17 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
295's should be OK IMO, keep the adjustable bearing though.
Mopar to the bone!!!
[Re: 72Swinger]
#2190837
11/06/16 06:25 PM
11/06/16 06:25 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
295's should be OK IMO, keep the adjustable bearing though. Wilwood rear brake setup calls for Green bearings and I have been planning on running that. How detrimental will that be?
#2190845
11/06/16 06:36 PM
11/06/16 06:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
People keep bagging on the greens. Properly utilized and setup they work fine. Improperly utilized they fail, surprise. Dr Diff just weighed in on this issue not too long ago, read what he says. Found the thread
[Re: Supercuda]
#2190886
11/06/16 07:49 PM
11/06/16 07:49 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
People keep bagging on the greens. Properly utilized and setup they work fine. Improperly utilized they fail, surprise. Dr Diff just weighed in on this issue not too long ago, read what he says. Found the thread With an open mind, read his list of negatives. Are they really that big of a deal?
#2190941
11/06/16 09:22 PM
11/06/16 09:22 PM
Supercuda
About to go away
About to go away
up yours
The negatives I see are against the tapered bearings.
#2190968
11/06/16 10:02 PM
11/06/16 10:02 PM
72Swinger
Nebraska
Ask the Hotchkis guys how well green bearings and Wilwoods work together.
[Re: ahy]
#2191253
11/07/16 09:57 AM
11/07/16 09:57 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
l
Wilwood brakes and straight roller axle bearings not so much on a handling car... what is your experience with this setup?
#2191507
11/07/16 03:17 PM
11/07/16 03:17 PM
72Swinger
Nebraska
Dan Wersharr said had to change those bearings twice or more each season IIRC. They get play then knock the pads back and you lose your pedal. To run a fixed rear caliper, a floater is pretty much mandatory. Otherwise run the Wilwood D52 caliper or Dr Diff.
