Re: 8-3/4 axle rebuild and what differential to go with
[Re: General 68]
#2188999
11/03/16 09:32 PM
11/03/16 09:32 PM
RapidRobert
I would purchase a good tight 742 case sure grip ready to drop in pig in the ratio you desire. all that is left is a ring gear gasket, axle bearings, (2) collars that lock the bearing in place (2) inner seals that you drive in the housing and the (2) flat flange seals, one has the threaded adjuster and the other is just flat with no adjuster, and a pair of white foam gaskets and a pair of the steel shim gaskets, the lube and a vial of SG lube. Plus your brake stuff EDIT the pig would need the (2) "buttons" and the roll pin that holds em together & likely it'll have em when you purchase it. these are the flat pieces installed on each side of the SG assy that the axle splined ends butt against them where they contact the SG so the end play can be set
[Re: General 68]
#2189689
11/04/16 09:42 PM
11/04/16 09:42 PM
Posts: 5,924 ohio
ruderunner
ohio
I'm a fan of the old (old!) Reliable Detroit Locker.
In a heavy long wheelbase vehicle, they work well.
Yes they have some quirks, clunk and sudden lock or unlock, but you get used to them and its no big deal.
Fwiw, I've logged over 200k miles with em and never had a problem.
Angry white pureblood male
