Re: Issues with MSD 6al digital
[Re: krautrock]
#2184008
10/27/16 07:33 PM
10/27/16 07:33 PM
Posts: 4,700 Wichita
GY3
Wichita
turn on lead for the msd gets 12v during crank and run from the ignition?
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes.
[Re: GY3]
#2184017
10/27/16 07:55 PM
10/27/16 07:55 PM
Posts: 2,094 central texas
krautrock
central texas
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes. i had a problem in my coronet when i put a 6al in, it would barely fire off when i let off the key from start. it was ign1 or 2, i forget. turns out the wire that i was using didn't get voltage in start, only run. i had to tie the ign1 and ign2 wires together to feed the msd turn on power. give that a try. i was working at the bulkhead, since much of my stuff was butchered...
[Re: GY3]
#2184031
10/27/16 08:14 PM
10/27/16 08:14 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes. The blue wire goes dead during cranking unless you have the stock ballast resistor in place and a factory, functional ballast resistor bypass wire connected to the stock starter relay.
[Re: @#$%&*!]
#2184040
10/27/16 08:19 PM
10/27/16 08:19 PM
GY3
Wichita
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes. The blue wire goes dead during cranking unless you have the stock ballast resistor in place and a factory, functional ballast resistor bypass wire connected to the stock starter relay. Ballast was in place but I bypassed temporarily with jumper wire.
[Re: GY3]
#2184057
10/27/16 08:45 PM
10/27/16 08:45 PM
Thigh-Gap Junction
You'd still need the wire from the starter relay to the coil side of the ballast resistor. It's easy to put a test light or voltmeter on the wire and see if there's voltage while cranking.
[Re: GY3]
#2184422
10/28/16 11:48 AM
10/28/16 11:48 AM
Posts: 5,166 CT
GTX MATT
CT
The blue wire the connects to the coil positive has power when the switch is on both start and run... IMO you have it wired correctly
[Re: GTX MATT]
#2184483
10/28/16 01:10 PM
10/28/16 01:10 PM
GY3
Wichita
The blue wire the connects to the coil positive has power when the switch is on both start and run... IMO you have it wired correctly Exactly! That's the way it is on my car and even in the MSD diagram. It DOES have spark to the distributor. You spin it by hand at higher RPM and it's fine. At cranking speeds, though, it doesn't spark. I'm beginning to think it's a bad box...
[Re: GY3]
#2184524
10/28/16 02:11 PM
10/28/16 02:11 PM
krautrock
central texas
so you have voltage during crank and run.
the car won't run? or the problem is your are not getting spark when spinning the dist slowly?
[Re: GY3]
#2184527
10/28/16 02:14 PM
10/28/16 02:14 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
I installed 3 6AL boxes with a Mopar electronic distributor, blew all three, spoke to MSD, they said they were compatible. They would work for about 10 seconds, than die.
Installed the old MSD unit, worked fine.
Installed a new MSD distributer with a new 6AL box, no other changes, still working. I took one of the boxes apart, it had a burnt out quad driver in it.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: krautrock]
#2196951
11/15/16 09:23 PM
11/15/16 09:23 PM
GY3
Wichita
An update on this. My friend ordered an old style analog MSD 6AL off of Ebay and I installed it today. It fired up on the first twist of the key! Nothing like wasting an entire day working on something only to find out the brand new box was trash!
[Re: GY3]
#2197020
11/15/16 10:43 PM
11/15/16 10:43 PM
Posts: 4,457 Washington
madscientist
Washington
An update on this. My friend ordered an old style analog MSD 6AL off of Ebay and I installed it today. It fired up on the first twist of the key! Nothing like wasting an entire day working on something only to find out the brand new box was trash! So analog isn't always bad.
[Re: madscientist]
#2197028
11/15/16 10:55 PM
11/15/16 10:55 PM
GY3
Wichita
An update on this. My friend ordered an old style analog MSD 6AL off of Ebay and I installed it today. It fired up on the first twist of the key! Nothing like wasting an entire day working on something only to find out the brand new box was trash! So analog isn't always bad. I've been hearing bad things about MSD here lately but didn't want to believe them... The MSD tech was worthless and pretty much decided not to help with anything after he found out I was hooking the box up to something other than an MSD distributor. It's a magnetic pickup distributor for chrissakes! Time to start hoarding the old stuff...
[Re: J_BODY]
#2197037
11/15/16 11:02 PM
11/15/16 11:02 PM
GY3
Wichita
....and hence the reason I'm still using the old school box. Sure like some of the features of the new digi stuff though. Exactly! They almost had me convinced to upgrade mine a few months ago. Not now!
[Re: GY3]
#2197068
11/15/16 11:58 PM
11/15/16 11:58 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I run a MSD digital 6 box and it has worked perfect for the last 5 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: GY3]
#2197155
11/16/16 01:35 AM
11/16/16 01:35 AM
madscientist
Washington
An update on this. My friend ordered an old style analog MSD 6AL off of Ebay and I installed it today. It fired up on the first twist of the key! Nothing like wasting an entire day working on something only to find out the brand new box was trash! So analog isn't always bad. I've been hearing bad things about MSD here lately but didn't want to believe them... The MSD tech was worthless and pretty much decided not to help with anything after he found out I was hooking the box up to something other than an MSD distributor. It's a magnetic pickup distributor for chrissakes! Time to start hoarding the old stuff... I'm already well into the hoarding process.
