Page 2 of 4 1 2 3 4
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218373
02/13/09 11:10 AM
02/13/09 11:10 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
A Duster, Demon with a 3100 lbs race weight and 500 flywheel HP would also be interesting in FAST. Could this be the first 10 second FAST small block.
Duster, Check
Weight, Check
Horsepower, building now
10's?, I'll take sub 11.50's.
I'm looking forward to the 09 season for sure.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Why no MW cars racing in FAST? [Re: CJK440] #218374
02/13/09 12:47 PM
02/13/09 12:47 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Duster, Check
Weight, Check
If anyone is going to get in the lead it's you. I think Tom is working too much on the bigblock stuff. I keep falling farther behind on where I would like to be.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Why no MW cars racing in FAST? [Re: F1Scamp] #218375
02/13/09 02:59 PM
02/13/09 02:59 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
What makes you think that
Re: Why no MW cars racing in FAST? [Re: scatpacktom] #218376
02/13/09 09:44 PM
02/13/09 09:44 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
500 hp in a 3100 lbs package should run 10.90 at 127.5 mph with a 1.70 60'. I would think that is very possible in a A body. I think the key will be to take as much weight off the front as possible so you can add 100 lbs of weight to the rear of the car and still end up 3100 with driver.
Getting old just means you were smarter than some and luckier than others.
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218377
02/14/09 07:50 AM
02/14/09 07:50 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
500HP at the wheels. My best of 11.93 was @ 115mph which calculates to be about 370 rwhp.
I'm building in a little more cubes and some more compression but its gonna be quite a feat to find 130rwhp.
Tom, get workin on that big motor!!
Re: Why no MW cars racing in FAST? [Re: CJK440] #218378
02/14/09 10:56 AM
02/14/09 10:56 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Duster, Check
Weight, Check
Sub 11.50's is definitely possible, I've done it with drag radials and a poor 1.72 60 foot time.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Why no MW cars racing in FAST? [Re: Rapid340] #218379
02/14/09 11:55 AM
02/14/09 11:55 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The 500 HP I used in the calculation was flywheel, 450 at the wheels would get you the same results. If the numbers that Dave got on his 340 build were not on a happy Dyno I think it's a possible goal. Easy, not saying that. Weight distribution and transfer will be key. What kind of 60's has Joel run in his Hemi car with a stick and at least 700 more lbs to launch on the same tire an A body will be on? I think I will call mine David.
Re: Why no MW cars racing in FAST? [Re: scatpacktom] #218380
02/14/09 03:17 PM
02/14/09 03:17 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Cause I know how much the T/A likes the back of the AAR.
Now that should get you motivated.
Just curious what hp does 3670lbs at 11.61 equate too?
Re: Why no MW cars racing in FAST? [Re: F1Scamp] #218381
02/14/09 06:34 PM
02/14/09 06:34 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Give me the MPH of that 11.61 run and I will tell you how much HP you are making. Is that the weight with driver? If that 11.61 was on poly's you probably making enough steam.
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218382
02/14/09 07:04 PM
02/14/09 07:04 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
11.61 @ 117mph was on poly's in the AAR. 3670 w/driver and a pretty hurt tranny. That motor will more than likely be making it's way into the 71 duster...
Re: Why no MW cars racing in FAST? [Re: F1Scamp] #218383
02/14/09 07:32 PM
02/14/09 07:32 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The motor is making 460 at the flywheel or 413 at the wheels. 40 more hp and a 3100 lbs with driver a-body, going to be a tough combo. Has anyone done any testing to see which is the best set up the six pack or the thermo quad? I wanted a 72 Demon so I would have fresh air.
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218384
02/14/09 07:40 PM
02/14/09 07:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Haven't done any testing, but it would be hard to imagine the T quad(even though it's a pretty good race carb) trumping a 6 pack. the manifold itself is much better.
MB
Re: Why no MW cars racing in FAST? [Re: HPMike] #218385
02/14/09 08:45 PM
02/14/09 08:45 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Mike I have not done any comparison to a Sixpack but the factory four barrel intake is quite good as I can remember the disapointment after laying my hard earned $4.00 an hour down for a LD340, and getting little to no performance increase. The 340-360 A body cars do well in stock eleminator and the intake and carburator are one of the reasons in my opinion.
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218386
02/15/09 09:25 AM
02/15/09 09:25 AM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Danny
I thought you where working on a Maxie? did you change gears to a small block?
Chris and Brian
You should never under estimate The Big Shooter I think he's all small block for 09 ??
Come on April
Re: Why no MW cars racing in FAST? [Re: XXHEMI] #218387
02/15/09 09:59 AM
02/15/09 09:59 AM
NY
aarmaniac Offline
aarmaniac  Offline
NY
I will NEVER under estimate Tom. Dave keeps putting these Hemi thoughts in his head.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
Re: Why no MW cars racing in FAST? [Re: aarmaniac] #218388
02/15/09 11:40 AM
02/15/09 11:40 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
well whatever can be done to the manifold is going to be done. I know the carb can be made to flow over 900+cfm. But to lose the fresh air is going to hurt big time. I can't wait to see what all these cars are going to do this year.
Re: Why no MW cars racing in FAST? [Re: F1Scamp] #218389
02/16/09 09:03 AM
02/16/09 09:03 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Chris and Brian
I hope so. That 11.57 sat quietly for way too long. I want to see it move in 09 even if the Big Shooter bests it himself, but then again, I'd prefer to get there first.
C'mon April is right!!!
Re: Why no MW cars racing in FAST? [Re: CJK440] #218390
02/16/09 09:31 AM
02/16/09 09:31 AM
St Clair Shores, MI
DonnyBrass Offline
DonnyBrass  Offline
St Clair Shores, MI
and I don't think Benoint is done with the LT-1 Corvette, either...........
Chevy infiltrator 12.34 @ 109.45 with a 1.73 sixty foot
Pure Stock
Re: Why no MW cars racing in FAST? [Re: DonnyBrass] #218391
02/16/09 11:09 PM
02/16/09 11:09 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The LT1 Vette is going to have to run a 4 speed and I don't believe you are going to get as many cubic inches with the Chevy. The A Body is going to be close in weight and 100 lbs in the Trunk will even it up on the weight distribution. LT1 is not near as good a package as the L88 and no auto. I'll take the Mopar.
Re: Why no MW cars racing in FAST? [Re: dannysbee] #218392
02/16/09 11:37 PM
02/16/09 11:37 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
You sure about all that Dan?
Page 2 of 4 1 2 3 4
