Re: whats a good head light up grade
[Re: theraif]
#2179264
10/20/16 05:44 PM
10/20/16 05:44 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
You could try these linky from Amazon. I have a pair but haven't installed them as yet. Maybe never since we took her Ramcharger out of daily service. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: lunacy]
#2179325
10/20/16 08:15 PM
10/20/16 08:15 PM
Posts: 141 Pennsylvania
polaris400cc
Pennsylvania
hella H6054 sealed beam conversion hella sealed beam conversion and headlight relay upgrade. It's the most dependable way to upgrade lights, plus take a big load off factory switches and wiring I would also add a note that says stay away from cheaper fancy looking conversions. They are just that cheap fancy "looking", not functional. And don't be one of the A-holes that runs HID bulbs in a halogen based housing, it just plain sucks for performance and jacks off every oncoming car.
[Re: polaris400cc]
#2179748
10/21/16 02:34 PM
10/21/16 02:34 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
hella H6054 sealed beam conversion hella sealed beam conversion and headlight relay upgrade. It's the most dependable way to upgrade lights, plus take a big load off factory switches and wiring I would also add a note that says stay away from cheaper fancy looking conversions. They are just that cheap fancy "looking", not functional. And don't be one of the A-holes that runs HID bulbs in a halogen based housing, it just plain sucks for performance and jacks off every oncoming car. One of the best upgrades done to my 92.
[Re: theraif]
#2179983
10/21/16 10:09 PM
10/21/16 10:09 PM
Posts: 5,943 ohio
ruderunner
ohio
Another vote for relays. Don't bother with a kit. Get some used relays from the junkyard, a few crimp on terminals and a couple feet of wire and inline fuse holders. Cheap easy and very effective.
Angry white pureblood male
[Re: ruderunner]
#2180743
10/23/16 10:19 AM
10/23/16 10:19 AM
Guitar Jones
I bought the kit from LMC, it's not expensive and super easy to install. I was going to make my own but the whole thing saved a lot of time and except for drilling a couple holes to mount the relays and two ground wires it was totally plug and play.
[Re: theraif]
#2183003
10/26/16 02:51 PM
10/26/16 02:51 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I agree on the relays. Before installing relays on my 93 ram, the headlights were dangerously dim. I measured 9 volts at the headlight, with the engine running. After installing relays, it had full alternator voltage to the bulbs, about 13.8V. That plus a pair of $5 Wagner H6054 halogen sealed beams, and it has incredibly bright lights! One caveat: at 9 volts, the sealed beams would last just about forever. Not so when you zap them with 13-14 volts. It seems that I only get about 2 years out of a bulb. But for 5 bucks, who cares?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: theraif]
#2185145
10/29/16 09:03 AM
10/29/16 09:03 AM
Posts: 2,262 Groveland, MA
SteveS
Groveland, MA
The Hella conversions are amazing.
Steve
Someday I'll have another C-body.
