which caliper brackets #2182007
10/25/16 09:34 AM
10/25/16 09:34 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
slider or pin type for 11 inch rotors? 69 b bodyfor factory calipers,which would better or both about the same. thanks
Re: which caliper brackets [Re: moparpro] #2182061
10/25/16 11:44 AM
10/25/16 11:44 AM
None
71rm23 Offline
71rm23  Offline
None
Hopefully member hemi71x sees this or send him a PM. He is more well informed on this since he does brakes (there are more too). I think they're pin type.
Re: which caliper brackets [Re: moparpro] #2182085
10/25/16 12:32 PM
10/25/16 12:32 PM
central il.
second 70 Offline
second 70  Offline
central il.
factory calipers were pin type. The sliders will fit but are for newer calipers
Re: which caliper brackets [Re: moparpro] #2182160
10/25/16 02:19 PM
10/25/16 02:19 PM
AndyF Offline
AndyF  Offline
Neither. A '69 B body had fixed calipers.
Re: which caliper brackets [Re: AndyF] #2182453
10/25/16 07:52 PM
10/25/16 07:52 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
If you already have BENDIX, 4 piston caliper, disc brakes, on your 69 B body, NOTHING else works on that system.
You change over the entire brake system, either pin type, or slider type, onto your car, single piston calipers.
Use whatever style brake system becomes available to you, for the swap.
Both systems are going to "brake" your car, and it's no problem in getting pads, calipers, parts, for either system.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: which caliper brackets [Re: moparpro] #2182674
10/26/16 12:06 AM
10/26/16 12:06 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think he means "brake" your car. Isn't it amazing what the potential impact can be from a simple spelling mistake.
Re: which caliper brackets [Re: Stanton] #2182756
10/26/16 02:20 AM
10/26/16 02:20 AM
When the time comes get some Ceramic pads & a bed in procedure is time consuming but very beneficial. EDIT they may want a coarser finish (have your lathe operator set a faster speed) or vice versa for ideal performance. More friction (rougher) is more braking (& faster wear) but see what the pad MFR says
