Re: Ignition Timing B-1 heads 15CR Alcohol
[Re: 440Jim]
#2181459
10/24/16 02:54 PM
10/24/16 02:54 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I run close to the same engine, just smaller (512). I run 32.5-33 degrees anymore and the power falls off a little. You do have some oil drain back lines don’t you?
Joe
Without Data, you’re just another guy with an opinion.
[Re: 440Jim]
#2181492
10/24/16 03:26 PM
10/24/16 03:26 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
on the B1 motor I built and dyno tested last year with two #8 return lines per head I had one pull that got extended do to operator error and we ended up filling the valve covers with oil enough to make it leak out the breathers with a 10 quart oil pan I used 90 degree elbows on the hoses to clear everything instead of 90 sweep ends The next B1 motor will have sweep ends instead of elbows
[Re: 440Jim]
#2181596
10/24/16 06:00 PM
10/24/16 06:00 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
FWIW our 525B1 made almost 1100 last time it was freshened and made max power at 32. Have done two others since one a 572 with near that compression and it was max power at 33 and also did a low deck 572 that made max power at 32 as well.
[Re: 440Jim]
#2181909
10/25/16 01:22 AM
10/25/16 01:22 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have no idea but I wish that engine was mine.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 440Jim]
#2182945
10/26/16 01:02 PM
10/26/16 01:02 PM
Posts: 16,931 NC
440Jim
NC
Yes he has oil drain back lines for the heads to the top/back of the oil pan (see fitting on oil pan in the pic). It has the T&D common shaft rockers that oil from the block/cam like a factory engine. He ran that cam before with these heads in a 511 CID. I didn't notice if the cam has the number 4 journal grooved or not (hopefully not, IMO). In its prior life, the oil drain back lines were in the front of the heads, and we moved them to the rear and added the fittings in the oil pan, the chassis has lots of room between the heads and the firewall.
It has one of those strange looking SV carbs with one big hole and fuel bars. He has been running the carb for awhile and I bet it flows around 1200 cfm, but it is still a single carb, cast, B1 intake.
He might be able to run the car at the Mopar event at Maryland International Raceway this Sat, Oct 29. But it may not be ready, he hasn't started the engine yet...
Thanks for the timing input. I was thinking around 32 also.
[Re: 440Jim]
#2182977
10/26/16 01:56 PM
10/26/16 01:56 PM
Posts: 403 southern Maryland
keefe
southern Maryland
{He might be able to run the car at the Mopar event at aryland International Raceway this Sat, Oct 29.}
Good deal Jim...will see you guys Saturday at MIR or MDIR or whatever it's called now days....LOL
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
[Re: 440Jim]
#2182987
10/26/16 02:14 PM
10/26/16 02:14 PM
Posts: 500 MD
JACK1440
MD
