Ram v-10 help #2181288
10/24/16 10:57 AM
10/24/16 10:57 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Help please
I have a 01 RAM 2500 v-10 that has a Miss under load it idles fine but when I put it in gear it has a stumble no lights on at all I'm thinking maybe crank/cam sensor going bad..... I can get it up to 65 but kinda have to feather it to get there
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Ram v-10 help [Re: 67mprfan] #2181411
10/24/16 01:55 PM
10/24/16 01:55 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Fuel pump/pressure issue maybe?
Re: Ram v-10 help [Re: 67mprfan] #2181476
10/24/16 03:08 PM
10/24/16 03:08 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
On the V8's that's sometimes a dirty idle air control. If your V10 has one, pull it out and clean it.
Next, would be to pull the O2 sensors, inspect, clean and re-install.
Last, could be plugged catalytic convertor. Has your fuel mileage taken a dump?
Mo' Farts
Moderated by "tbagger".
Re: Ram v-10 help [Re: 67mprfan] #2181495
10/24/16 03:30 PM
10/24/16 03:30 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
I have never paid attention to gas mileage because it's a v-10 but I did put some more gas in it and it seemed to clear up a little.... where is the fuel pump in the tank
Re: Ram v-10 help [Re: 67mprfan] #2181541
10/24/16 04:39 PM
10/24/16 04:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have read that V10's are sensitive to plug wire routing, some kind of cross firing issue?
