Ne1 here own a Gray 73 Dodge Charger SE Update #217925
02/08/09 03:08 PM
02/08/09 03:08 PM
Iowa
73ChargerSE440 Offline OP
Iowa
Need restoration tips, was the underside painted body color or black? The car having 151K miles on it is hard to tell was was original and what was modified for example the red grille inserts are gone, maybe taken off for another car.
67 Ply. Belvedere II 2dr Hardtop 73 Dodge Charger SE 440+6 727 Dana 60 4.10 78 Chrysler Cordoba 400-4 727 9 1/4 3.21 1999 Dodge Diesel 2500 QuadCab Longbox 2004 Dodge Durango HEMI Limited
Re: Ne1 here own a Gray 73 Dodge Charger SE Update [Re: 73ChargerSE440] #217926
02/08/09 05:02 PM
02/08/09 05:02 PM
Iowa
Iowa
can u drop the engine out like the other mopars by taking the K-member out?
Re: Ne1 here own a Gray 73 Dodge Charger SE Update [Re: 73ChargerSE440] #217927
02/08/09 06:09 PM
02/08/09 06:09 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
I used to have a gunmetal U code Charger S/E.It was nicely optioned...tips ,tach,suregrip,air etc.The 73-74 B 's are painted pretty much the same as all the earlier B's...primer bottoms with overspray around the edges.Okay for a show poodle but if you are going to drive it I'd do the whole bottom in black.The K member does come out as a unit along with the isolated T bar crossmember.Might as well replace all the worn out K and crossmember bushings with poly pieces while you are at it.
"Long Live Mopars"
Re: Ne1 here own a Gray 73 Dodge Charger SE Update [Re: Furyman] #217928
02/08/09 08:24 PM
02/08/09 08:24 PM
Iowa
Iowa
