Hinge and latch grease #2179119
10/20/16 01:24 PM
10/20/16 01:24 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I need to re-grease the various hinges and latches on my car so I'd like to know what type of grease is recommended for this. Would I use something like white lithium grease, wheel bearing grease or something else?
Re: Hinge and latch grease [Re: 440mopar] #2179149
10/20/16 02:19 PM
10/20/16 02:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
No grease, it will make a mess and not get in tight areas too well.
I use Tri-flow spray lube with Teflon. Hinges, locks and latches, window regulators, etc. It gets into the pins and small parts easily, and lasts much longer than WD-40. Use it every fall on the daily drivers also.
