Re: 727 low gear sets [Re: racerx] #2852571
11/28/20 02:28 PM
11/28/20 02:28 PM
The low gear set that Mopar use to sell for the 727 had a different 2nd gear ratio than the standard stock 2.45 gear sets had, I don't remember that ratio now whiney
That car went the fastest with that low gear set up and rear gear ratio boogie
I did notice that it went into high gear sooner so it did spend more time in high gear than it did before also work Thinking back now I kinda wish that I had made one change at a time but I didn't. The Aluise family in Maryland ended up with that car in 1990 and spent a lot of time and money on turning it into a rocket ship, it held the NHRA AS/A record a number of times in the 1990s.
I wonder were it is now shruggy
Re: 727 low gear sets [Re: Cab_Burge] #2852574
11/28/20 02:39 PM
11/28/20 02:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
"Breathless"? Remember it well. It was bad. IIRC they got jammed up with tech over something in that car. No clue where it is but I bet I could find out. They may have it stuck in a building somewhere.
Re: 727 low gear sets [Re: Cab_Burge] #2852796
11/29/20 02:02 AM
11/29/20 02:02 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
when you add the wide ratio 274 low it also changes 2nd gear ratio!
Re: 727 low gear sets [Re: calrobb2000] #2852818
11/29/20 09:09 AM
11/29/20 09:09 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by calrobb2000
hi
So what gear ratio does the second gear changes to shruggy?
Re: 727 low gear sets [Re: racerx] #2852824
11/29/20 09:44 AM
11/29/20 09:44 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
2.74 1.54 1.00 V's the stock 2.45 1.45 1.00.
Re: 727 low gear sets [Re: Tig] #2852825
11/29/20 09:54 AM
11/29/20 09:54 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks Tig up
