Re: 505 Overheating!!
[Re: Shatar4]
#2171456
10/10/16 01:45 PM
10/10/16 01:45 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
[Re: Shatar4]
#2171465
10/10/16 02:07 PM
10/10/16 02:07 PM
Posts: 15,459 Omaha Ne
TJP
Omaha Ne
I would start by verifying you readings with a thermocouple probe and digital meter. it is the most accurate way to determine the actual readings. The probe should be placed as close as possible to the Thermostat or existing temperature sender. I have seen a number of aftermarket gauges be off by as much as 40 degrees and usually on the on the warmer end. Should you confirm the readings, What you are describing indicates, one of the following, A tuning issue, IE: lean mixture, too much or not enough timing, or possibly a restricted exhaust. Undersized radiator, or inadequate air flow through the radiator. The air flow can be compromised by the fans / shroud design if it has one. it can also be comprised by openings in the radiator support that can allow the air to go around rather than through the radiator core. only other possibilities I can think of is If the lower hose is sucking shut at increased RPM or a loose impeller on the water pump. Keep us posted One more thing just popped into my head, Pulley ratios being off causing the pump to be driven to fast or not fast enough.
[Re: Shatar4]
#2171474
10/10/16 02:17 PM
10/10/16 02:17 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd put a Milodon pump in an oem iron housing.........after verifying the lower hose has a spring in it and isn't being sucked in.
[Re: Morty426]
#2171511
10/10/16 03:30 PM
10/10/16 03:30 PM
RapidRobert
You dont have enough water flow, something is restricting it somewhere. I would change the pump to a regular non scroll (vane) type & if still bad then change the housing to an OE iron one with the source scroll pump back in it & if still bad then keep the iron housing & change the source pump to a regular vane type. housing (restricted) or pump (scroll type not pumping enough at speed)
[Re: RapidRobert]
#2171522
10/10/16 03:49 PM
10/10/16 03:49 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
You dont have enough water flow, something is restricting it somewhere. I would change the pump to a regular non scroll (vane) type & if still bad then change the housing to an OE iron one with the source scroll pump back in it & if still bad then keep the iron housing & change the source pump to a regular vane type. housing (restricted) or pump (scroll type not pumping enough at speed) If that was the case he would over heat at idle. Either he has too muck flow and no time to cool in the radiator or he's running too lean. I vote for the later
[Re: Shatar4]
#2171523
10/10/16 03:49 PM
10/10/16 03:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You have a crap ton of non-stock stuff on there.
Have you verified that the pulley ratios are close to stock?
Not running an underdrive setup are we?
[Re: Shatar4]
#2171525
10/10/16 03:53 PM
10/10/16 03:53 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
I have a 440 source pump & housing, 512 cid, cold ac, in temps of 105 + my car runs 185, make sure the new radiator did not get plugged up with rust flakes from the block.
[Re: Morty426]
#2171532
10/10/16 04:03 PM
10/10/16 04:03 PM
RapidRobert
(1) yes if the flow was real inadequate it would overheat at idle but I think he has enough flow to cool at idle but not enough flow at higher speeds where more eng heat needs more cooling. (2) (just me) I believe that too fast of flow being an issue is an old wives tale (& the Nascar Stewart water pump mfr are of the same belief) cuz if one block of coolant is moveing faster thru the rad (& gets cooled less) then that means that the next block of water arrives faster & begins getting cooled faster & all it reaches an equilibrium & that reports of people speeding up the flow (pulleys/vanes) & reporting running hotter, I believe they made some OTHER change in addition to that at the same time that is the real cause. One change at a time is a hard & fast rule & causes alot of problems if not adhered to. OP, post the outcome!
[Re: RapidRobert]
#2171563
10/10/16 05:07 PM
10/10/16 05:07 PM
Posts: 76 Florida
Interceptor72
I believe that too fast of flow being an issue is an old wives tale (& the Nascar Stewart water pump mfr are of the same belief) True. It's an old wives tale and it's false. Basic laws of thermodynamics state otherwise. Basically, the rate of heat transfer is proportional to the differential in heat. If the hot water stays in the radiator, then yes it cools down more, BUT the rate of heat transfer ALSO slows down (and meanwhile the water in your engine bock is STILL heating UP...seems like people forget that part) SO the best thing you can do is keep transferring more of the hottest liquid (that's from the block) straight to the radiator as fast as you can for the fastest heat transfer away from your block and to the atmosphere. If you are still overheating after you know you have as good of a water flow as can be reasonably expected, then the function of your radiator is suspect (not enough capacity, bad airflow from bad shrouding, etc.) And cavitation from poorly designed water housing/water pumps can mean that spinning the water pump faster results in LESS water flow, which people improperly interpret as "too much water flow", when it's really the opposite.
[Re: Dave Hall]
#2171626
10/10/16 07:01 PM
10/10/16 07:01 PM
RapidRobert
Dave, more info please, overheating at idle or stoplight to stoplight or at higher speeds? what idle timing? no vac leaks?-(that is a long(er) shot but never hurts to ask. flex or rigid fan? schroud? how far is fan into schroud? radiator in good shape? any parts or adjustment changes preceding the onset? mixture/puller ratio in the ballpark (longer shots still).
[Re: ahy]
#2171643
10/10/16 07:45 PM
10/10/16 07:45 PM
Posts: 1,038 Howell, Mi
Shatar4
Howell, Mi
Well you guys gave me a bunch to look at so first thing I'll try is the tuning. I have a Firecore dizzy and we locked it out at 36 degrees. Here's a pic of the radiator
