Re: Do you fill your oil filters before installing?
[Re: monoptn]
#216806
02/08/09 01:30 PM
02/08/09 01:30 PM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
We all have our opinions on this subject and some are more pigheaded about the yea's or nay's of prefilling it or not. I say, "A ounce of prevention is worth a pound of cure!" I have been doing it for years and I have noticed that in some cars, knocking as well as the pressure comes up quicker with pre-filling the filter first. The way to prevent oil from spilling out is to fill the filter first and let it sit while you drain the pan. You will notice that the oil has been soaked into the filter. I have even gone as far as adding more to the filter to ensure it's full. To each there own. Hey, you do what you do, and I do what I do!
[Re: MoparforLife]
#216808
02/08/09 02:54 PM
02/08/09 02:54 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Right on Little Brother. He does what he has to do and I do what I have to do. He is the Baby after all...Gotta Love him....
[Re: Michael]
#216810
02/08/09 06:31 PM
02/08/09 06:31 PM
Posts: 146 michigan
tonycpe
michigan
So that's why a slant six sounds like an old type writer.
Old Fogey Racing Ltd.
[Re: tonycpe]
#216811
02/08/09 06:54 PM
02/08/09 06:54 PM
RapidRobert
this is the last time I am going to open this thread. Now where is my preoiling shaft
[Re: MoparforLife]
#216813
02/08/09 07:20 PM
02/08/09 07:20 PM
Posts: 75,016 U.S.S.A.
JohnRR
U.S.S.A.
X2
[Re: Pacnorthcuda]
#216814
02/08/09 07:21 PM
02/08/09 07:21 PM
JohnRR
U.S.S.A.
And as the poll states...three out four of us do it. Notice that not one person has offered up a why not reason other than the chance of spillage, and coming from someone who doesn't do it, how would they know how NOT to spill?
why beat the subject to death ? you are NOT going to change the mind of those that have their mind made up on the subject .
[Re: JohnRR]
#216815
02/08/09 07:25 PM
02/08/09 07:25 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Not out to change anyones mind, just find it interesting. Kind of a sharing of experiences/practices/ideas. Oh wait thats Moparts! I am surprised this thread has continued so long, and yea I am part of the reason--so are you John! Enjoy
[Re: MoparforLife]
#216817
02/08/09 07:37 PM
02/08/09 07:37 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
Well, here`s a little tidbit for y`all right out of the FSM for my truck:
(7) Using a new pressure relief valve gasket, install the relief valve plug. Tighten the plug to 20 N·m (15 ft. lbs.) torque. (8) Install oil filter that has been filled with oil.
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: gamagoat6x6]
#216818
02/08/09 08:00 PM
02/08/09 08:00 PM
Posts: 18,422 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Is that not from a pump repair section? I believe they want you to do it that way so the crank driven pump does not lose its prime. What does the book state in the maintence section on filter change??
[Re: 6PakBee]
#216819
02/08/09 08:16 PM
02/08/09 08:16 PM
DaytonaTurbo
Manitoba, Canada
I never did prefill an oil filter. I suppose it's a good idea, I just never bothered. No reason not to, no reason to either, I don't think any engine has ever been harmed by it. If the engine was actually losing critical oil pressure during a dry start-up I think we'd hear something, be it lifters bleeding down or whatnot. I watched the oil pressure gauge on mine after an oil change and the extra time it took to start building oil pressure(compared to normal) was almost nothing. Quote:
When I had my turbo Daytona,they told me point blank I'd better prefill it by cranking the engine over with the coil wire grounded. They claimed they had actually replaced some turbos and had seen premature turbo failures due to oil changes when people started them up with dry filters.
I have to LOL at that. At idle speed the turbine on the turbo is not even spinning, or if it is, it's barely just slightly moving. So unless you change your oil, start the engine up and immediately mash the pedal to full boost, I don't see how you could have a problem. Even then oil would get there so quick you could never do any damage.
[Re: DaytonaTurbo]
#216820
02/08/09 08:25 PM
02/08/09 08:25 PM
Posts: 2,886 US of A
A38s!
US of A
I had an old 93 VW VR6 with the open element cannister filter. Loved it. Was super easy to prefill. Cap was almost 6 qts full. Got me in the habit to do with everything I can.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
[Re: A38s!]
#216821
02/08/09 08:36 PM
02/08/09 08:36 PM
Posts: 4,420 Michigan
MarkZ
Worthy
Worthy
I always fill my oil filters prior to installing them. Even on my F150 I6 where the filter is mounted horizontally. I can at least get it half full without spilling a drop.
[Re: bigD]
#216822
02/08/09 08:41 PM
02/08/09 08:41 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FWIW, some filters have a standpipe for use in "upside down" installations, the Baldwin B253 has the same mounting dimensions as the typical Mopar and has a standpipe to help prevent drainback.
