Re: Real Time Engineering or RTE
[Re: Suregrip391]
#1990255
01/13/16 10:43 PM
01/13/16 10:43 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I just bought a tach upgrade board directly from them on their website. Transaction went smoothly and the board arrived a week later. I installed the board and it works as advertised.
I would have not problem recommending them.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: gtx6970]
#2166969
10/03/16 12:25 PM
10/03/16 12:25 PM
loco340cuda
Tempe, AZ
The installation was pretty straight forward and simple. You just need to know how to use a soldering iron.
Here are a couple of pictures after I completed the conversion...
[Re: 71birdJ68]
#2167309
10/03/16 09:13 PM
10/03/16 09:13 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Just a tid bit, I sent my tach to them for the install, so that they could calibrate it to the new board. The boards have a calibrate mode which is pretty easy to use. From my recollection, you just set the dip switches for two different RPMs and adjust the potentiometer for the proper reading.
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: KWF340]
#2167323
10/03/16 09:47 PM
10/03/16 09:47 PM
loco340cuda
Tempe, AZ
Just a tid bit, I sent my tach to them for the install, so that they could calibrate it to the new board. The boards have a calibrate mode which is pretty easy to use. From my recollection, you just set the dip switches for two different RPMs and adjust the potentiometer for the proper reading. Agreed, I remember calibrating the board, it was very simple to do and if I recall correctly it hardly needed any calibrating.
