Page 1 of 9 1 2 3 4 5 6 7 8 9
Garage Project #2163959
09/28/16 10:31 PM
09/28/16 10:31 PM
Western Md.
skicker Online tonguue OP
"The Champ"
skicker  Online Tonguue OP
"The Champ"
Western Md.
I started building this a couple years ago and am progressing as money will allow.
It will be a 28x40 with an 11x39 basement 9' high underneath the back half.
The garage level is set up to accept a 17x27' working bay with a 21x27 bay for car storage with a solid wall between the two.
There will be two pocket doors creating a 4' opening between the two sides. I managed to pick up a 4 post lift for the storage side.
After permits...public hearings and lawyer fees out of the way I have finally managed to make some progress. I'm planning on heated floors and using scissor truss's to add interior height for the lift.
...FAFO...
Re: Garage Project [Re: skicker] #2163970
09/28/16 10:43 PM
09/28/16 10:43 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Excavation and foundation work began in 2014... these pictures begin when work resumed in June of 2016. All block is 12" with the top course a 6" to create a pour stop for the concrete slab. You can see in the pictures the beam pockets where the steel beams will be placed.
...FAFO...
Re: Garage Project [Re: skicker] #2163978
09/28/16 10:52 PM
09/28/16 10:52 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The Basement wall is in center and had to be engineered to pass the county specifications due to the load created by the dirt against it.
The blocks are cut to create a bond beam with 2 layers of 3/4" rebar running the full length while 1 piece of 3/4" rebar runs vertically 32" oc.
...FAFO...
Re: Garage Project [Re: skicker] #2163981
09/28/16 10:57 PM
09/28/16 10:57 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The block work was completed and the beam pockets and bond beams were poured full of grout.
Steel plates were added to carry the point loads of the W8-15 beams yet to come.
The weld marks you see are where a J hook is welded to them and submersed into the grout.
They can be seen laying upside down on the wall in the last picture.
...FAFO...
Re: Garage Project [Re: skicker] #2163988
09/28/16 11:01 PM
09/28/16 11:01 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The beams are set into place and the metal decking stocked on top of them.
...FAFO...
Re: Garage Project [Re: skicker] #2163996
09/28/16 11:10 PM
09/28/16 11:10 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
This is the point where all the hired help's work is complete. They managed to do all of that in a week. From here on out this is all mine to handle until wall framing is ready to start next spring.
I started laying out the metal deck...shooting it down and installing the expansion joint at the block for the floor slab. I at least now have a half-a$$'d basement to store materials in.
...FAFO...
Re: Garage Project [Re: skicker] #2164003
09/28/16 11:15 PM
09/28/16 11:15 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
More expansion joint work and metal pan installation.
...FAFO...
Re: Garage Project [Re: skicker] #2164020
09/28/16 11:22 PM
09/28/16 11:22 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
With enough work done to the metal decking to get reasonably dry storage downstairs I started waterproofing the foundation walls and installing the foundation drains. This proved to be both time consuming and back breaking work in the middle of the summer.
The drains are covered with filter sock and wrapped in a bed a gravel surrounded by drainage material.
...FAFO...
Re: Garage Project [Re: skicker] #2164026
09/28/16 11:25 PM
09/28/16 11:25 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
It was about then that I realized I had better get under ground electric out to the future shed adjacent to the garage. Not to mention tie in the incoming electric service conduits.
...FAFO...
Re: Garage Project [Re: skicker] #2164037
09/28/16 11:36 PM
09/28/16 11:36 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Digging a 36" deep trench in the ground for the electric that was about 20' long is a PITA but I didn't have to rent a machine.
I also had to incorporate the storm water management underground plumbing into this area to be continued on later.
The entrance porch framing also began. I need this to double as a pour stop for the concrete slab.
...FAFO...
Re: Garage Project [Re: skicker] #2164050
09/28/16 11:48 PM
09/28/16 11:48 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Foundation drains continue at the basement wall in the area that will become the upper garage slab. I wasn't sure if water could make it to this wall or not so it received 2 coats of tar and the same drainage pipe and filter sock with gravel and material. They are on top of the foundation but that is 4" below the basement slab so any water should drain off.
These drains were the toughest because of the ground wanting to slide into the area you needed to work. I ended up doing these in 5' at a time increments and throwing the dirt I was removing back on areas that were completed.
Once this was complete the 70 tons of shale were brought in to fill the front where the floor is slab on grade.
...FAFO...
Re: Garage Project [Re: skicker] #2164057
09/28/16 11:56 PM
09/28/16 11:56 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Add in another 7 ton of #57 gravel topped off with 6 tons of Limestone dust and it is almost up to elevation. I used some water and a tractor along with the dually full of gravel to roll the shale for compaction. Then added the 57's and stonedust using a vibrating plate.
Finally I added the 1 1/2" foil faced rigid insulation for under the slab.
...FAFO...
Re: Garage Project [Re: skicker] #2164060
09/29/16 12:03 AM
09/29/16 12:03 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
In case your wondering what the two large holes in the insulation are those are the areas of the floor where the slab is beefed up thicker with rebar for the point loads created by the four post lift. Its a 36" diameter hole about 12" deep and will eliminate any future problems.
Time to start turning down the vertical rebar from the basement wall and installing the rebar and wire mesh in floor.
...FAFO...
Re: Garage Project [Re: skicker] #2164064
09/29/16 12:12 AM
09/29/16 12:12 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
About now is when the fun really starts. The 6x6 wire mesh and rebar were something that totally wiped me out. I used two rolls of the black wire tying everything together. Only to then begin installing 1200 linear foot of 1/2" pex tubing. (4 separate loops 300' each)
Sorry about the picture quality I think going from the AC to outside fogged it up.
...FAFO...
Re: Garage Project [Re: skicker] #2164072
09/29/16 12:20 AM
09/29/16 12:20 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
The two holes in the metal deck with metal around them you see are pour stops for future AC and a place to lower engines and other heavy items into the basement.
I used 3/4" 90 degree pvc elbows to create the penetrations for the pex to go into the basement. This should make sure I have no future problems.
I have since added a pour stop for the slab at the front doors but haven't completed it yet. More pics to come as this progresses. The main goal for this summer was to complete the concrete slab and all of the ground work so grass could be planted in the spring. So far...so good.
...FAFO...
Re: Garage Project [Re: skicker] #2164108
09/29/16 01:36 AM
09/29/16 01:36 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
Here is a drawing I did for the pex heating system in the floor. I used an overlay of the 6x6 metal mesh condition and then used the mesh spacing to develop a layout with 4 zones of equal length and near equal coverage. I'll have to take final pics of everything before concrete to make sure if I ever drill the floor nothing is in the way.
Also attached is the revised basement beam layout for the lift that gets installed above. I had to upgrade from a W8-13 to a W8-15 to manage the point loads the lift creates
As a running total so far there has been 10 truckloads of 57's used in the slab on grade and as back fill around trench and foundation drains. The average load weighed about 6,600 lbs and was unloaded by hand and distributed in 5 gallon buckets. 6 tons of limestone dust on top of that with the shale the total amount of materials imported was about 108 tons.
...FAFO...
Re: Garage Project [Re: skicker] #2164181
09/29/16 08:11 AM
09/29/16 08:11 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Wow.
Why did you use block vs poured foundation walls? Avoiding cost of pump? Access issues?
Could not tell from the pictures, but the interior block wall at the front of the basement I would have waterproofed as well.
Will be a nice shop when done.
Re: Garage Project [Re: skicker] #2164203
09/29/16 09:46 AM
09/29/16 09:46 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Nice work. Looking forward to seeing finished project.
Re: Garage Project [Re: larry4406] #2164254
09/29/16 11:49 AM
09/29/16 11:49 AM
Western Md.
"The Champ"
"The Champ"
Western Md.
Originally Posted By larry4406
Wow.
After numerous attempts to have 3 separate contractors bid on this I finally got one that did a site visit.
Because of the location being so far from the road and where a pump truck could actually set up and then be loaded by cement trucks it wasn't feasible. Its about 75' to the front away from a somewhat level portion of ground near the road. Originally that was the plan using the forms that would simulate brick for the outside.
The center wall at the basement only received tar 4' high with a drainage pipe at the bottom. With 15' of interior concrete slab in front of it and the front foundation dropping down a little over 3' I don't think water can get there.
I called the local contractor who did the excavation about this also. After looking at it he thought it was overkill to go 4' high but I'd rather be safe than sorry.
I have also ran a pipe from the front rh corner underground to the alley in the rear that will attach to a trench drain in front of the concrete aprons to the garage floor.
With the water filter material buried in the gravel about 20' wide this should catch the majority of water in a heavy rain from ever being able to get underground to cause a problem.
The last drawing indicates the pipe in purple, the dark grey at the doors is a 3' concrete apron and the dark area is the filter media buried in the gravel.
...FAFO...
Re: Garage Project [Re: skicker] #2164586
09/29/16 07:09 PM
09/29/16 07:09 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have built two hillside homes... Your pics brought back some memories and some pain... LOL
Keep up the good work... Looks like you are doing it right...
