Re: engine siezed, any thoughts on why
[Re: RapidRobert]
#2183701
10/27/16 12:10 PM
10/27/16 12:10 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Here we go !! Agreed, I shoulda known better than to take the bait. Wont happen again (cross my heart & hope to die) You know you are lying to yourself, you will take the bait, you always do ... Thank you, another post ... ding ...
[Re: JohnRR]
#2183874
10/27/16 04:40 PM
10/27/16 04:40 PM
Posts: 7,195 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Here we go !! Agreed, I shoulda known better than to take the bait. Wont happen again (cross my heart & hope to die) You know you are lying to yourself, you will take the bait, you always do ... Thank you, another post ... ding ... Now if he only learns how to take the cheeze without springing the trap...
[Re: RapidRobert]
#2190320
11/05/16 09:56 PM
11/05/16 09:56 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
I have to much time invested in this thread to see it fade away :-)
who is that guy?
[Re: NANKET]
#2197091
11/16/16 12:32 AM
11/16/16 12:32 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Robert posts 20 times a day, when he knows the answer he will tell us. Only 20?
...FAFO...
[Re: gdonovan]
#2210597
12/09/16 11:56 AM
12/09/16 11:56 AM
RapidRobert
I left him a message 3 or 4 days ago but I ain't heard back from him yet. the last time we spoke roughly a month or so back he said something about working on the interior & some other non engine related areas which was dissappointing cuz we need to get to the bottom of this but since it ain't my deal I gotta just go with what is presented to me but he does know that from me being involved in this deal that I also want resolution to this & that I am willing to help him achieve that & he has expressed appreciation for that interest/concern. I will post the outcome.
Re: engine siezed, any thoughts on why. UPDATE!
[Re: RapidRobert]
#2283740
04/07/17 01:51 AM
04/07/17 01:51 AM
RapidRobert
I spoke with him this evening. the shop that did the machining tore it down and ALL bearings are wiped smooth & clean (rods & mains) including thrust surfaces on #3 main halves EXCEPT the #4 main had spun. He (the owner) saw the bearings but did not take off the cap on the spun #4 main. this shop polished the crank (std), owner ordered std clevite bearings from Summitt. he recollected to the best of his ability that he plastigaged em at 2&1/2 tho. Assembly lube used. it was showing 80 lbs when we broke it in till it locked 4 minutes later. I told him either (1) wrong machining (2) oil psi or (3) debris & I wouldn't think debris cuz he said they were all smooth & it had 80 lbs at the sender but bearings can get starved especially the #4 main & rods on either side of it that feed from that main, but this was a 2200 RPM breakin, not high RPM & I said my money is on improper clearances. that's the latest guys, any thoughts? Oh & the #4 main cap was blued & he is going to source another cap & have another shop line bore it then the same (1st) shop that originally did the machining, put the short block together (not what I would do). I offered to put it together for him for free. EDIT He said the shop called in some other machinists to check it out & they are at a loss (I suspect they ain't miked anything yet, just visual.
[Re: 1971 Gran Coupe]
#2283760
04/07/17 02:56 AM
04/07/17 02:56 AM
RapidRobert
it is too challenging to let go especially with all the interest you guys have shown me on this and the puzzling development on the visual. I'm looking forward to eyeballing it in person as this is second hand info.
[Re: srt]
#2283768
04/07/17 03:50 AM
04/07/17 03:50 AM
RapidRobert
I ain't sure if startup rotation was mentioned priorly. He took some some pics that he is going to send & I'd like to be there in person before it goes together, I will for sure post any new info. EDIT what sounds strange to me & to them (& the people they called in) is that all the bearings are wiped smooth
[Re: justinp61]
#2283836
04/07/17 10:57 AM
04/07/17 10:57 AM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Interesting. Based on the autopsy it sounds to me like #4 was too tight due to the wrong bearing (undersize bearing in a standard bearing box) or there was insufficient oil supply to the #4 bearing. If the builder did indeed plastigauge all the bearings or the engine turned over at assembly, then I would guess an oil problem. 50 years ago I was working on one of the old babbit pounder 216 Chevys that have the oil dippers on the rods for rod lubrication. The engine was in the car and I got disoriented and got one dipper on backwards. The engine ran for about two minutes and locked up. The rod I had assembled incorrectly had fused itself to the crank and the rod was a pretty deep blue color. This sounds similar.
[Re: justinp61]
#2283856
04/07/17 11:27 AM
04/07/17 11:27 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
IMO the bearing clearance was to tight. You don't wipe or spin main bearings with .0025" clearance on a new engine with 80# of oil pressure. If it didn't have oil pressure the top end would've been very noisy. I think the tight or lack of clearance is why he had 80 PSI. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: RapidRobert]
#2283926
04/07/17 01:20 PM
04/07/17 01:20 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I think this is a good example of what can happen when someone lacking engine building experience is left to do it by themselves.
Unless there was no assembly lube, or a plugged feed hole to the #4 main, there is no way the crank would have passed the "feel" test for how it turned over.
I've seen where main journals on the crank or the main line itself is out if whack, to the point where the clearances measured fine, but the crank didn't feel "right" when turning it over........ And on a couple of occasions it actually locked up when all the caps were torqued. I've had this happen twice. Once the problem was the block, once it was the crank.
[Re: 3hundred]
#2283929
04/07/17 01:34 PM
04/07/17 01:34 PM
RapidRobert
good call on the psi & even tho it was a hi vol pump (not sure what spring), that number sure kinda points to minimal overall leakage. Evidently they did not mock it up/mike clearances after they did their work as he ended up plastigaugeing it himself (that had been bothering me from early on). I'm gonna see if I can drive up to the machine shop & take a look at the carnage.
[Re: RapidRobert]
#2284207
04/07/17 11:13 PM
04/07/17 11:13 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
With a 1st time engine builder, I have to wonder if the #4 main that spun was incorrectly installed. If the lock tabs were not in the grooves, the clearance at the bottom may have been OK, but the sides could have been very tight, causing the shells to spin as soon as the heat came up. The bearing shells could have begun spinning on start up, and it took 4 minutes to create enough heat to lock the motor. You are all assuming the new builder had the bearings correctly located.
If the #4 main bearing spun bad enough to lock the motor and turn the cap blue, and the other bearings look OK, how are you ever going to determine the real cause other then to point to #4 spun bearing and its blue cap? Gene
