Re: engine siezed, any thoughts on why
[Re: NANKET]
#2174295
10/14/16 02:26 AM
10/14/16 02:26 AM
RapidRobert
Let us know what you find in there when he opens it. For sure, with all the love I've gotten on this deal I will garner all the details
[Re: RapidRobert]
#2174756
10/14/16 07:07 PM
10/14/16 07:07 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
The plug may be missing, good point. This engine defies all odds
[Re: NANKET]
#2174785
10/14/16 08:04 PM
10/14/16 08:04 PM
RapidRobert
He cut the filter open & said it was clean. I'll get back after him next week
[Re: RapidRobert]
#2175204
10/15/16 12:46 PM
10/15/16 12:46 PM
Posts: 2,814 Connecticut
FurryStump
Connecticut
In the small block tech archive the is a post about changing oil pumps. About halfway down it talks about how to check to see if the plug is in there through the oil sending port using a small rod. It has the dimensions for how far the in the rod should slide in. The plug diverts oil to the filter. That plug is the DEVIL! Can you image pulling it apart and never finding any reason why it ate itself, because there would have been nothing wrong in the bearing assembly, it would show pressure, you would finally chalk it up to that mystery "issue" putting it back in and if does it AGAIN!!!
[Re: FurryStump]
#2175541
10/15/16 11:07 PM
10/15/16 11:07 PM
RapidRobert
My last circle track eng iirc the rod stopped 7&1/4" down from flush with the NPT oil sender port at the rear top of the block after I drove it in down visually halfway between the 2 horizontle ports. with no plug yes with alot of debris that could easily cause an immediate problem or if there is no significant debris the eng will wear out years before its time with the owner having no clue what is actually happening, all the while doing religious oil/filter changes & thinking he is golden! I will call the guy again soon. EDIT I could see where a non Mopar shop could easily miss that detail.
[Re: RapidRobert]
#2180172
10/22/16 07:27 AM
10/22/16 07:27 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
He cut the filter open & said it was clean. I'll get back after him next week Update?
"I think its got a hemi"
[Re: fastmark]
#2180225
10/22/16 11:09 AM
10/22/16 11:09 AM
Posts: 3,374 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Seems like there needs to be time limit on a question like this. All of us motor heads need conclusion. 😃 I think this thread is just a joke to see how long he can keep a bunch of gear heads in suspense. Tease us with the possibility of engine carnage pictures, and then leave us hanging....:)
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2180285
10/22/16 01:10 PM
10/22/16 01:10 PM
RapidRobert
Fastmark I'm going as fast as I can (& I got 2 calls in to him). Wingman, I do not operate like that, everything I have posted regarding this (& any of my posts) has been straight up). I posted the question & I sure was not expecting it to take off like it did but the guy has a wife and kids and a full time demanding job (& from what I understand a schedule that changes shifts) so there is not much I can do except keep in touch which tells him that I am interested in resolving this. I'm looking forward to a resolution too & in fact I was a little reluctant to put his business out here (not sure if he is on here or not) but my intent was honorable & I figured I needed to hear what the Mopar brain trust has to say for possibilities (& I sure got em!)
[Re: TJP]
#2180302
10/22/16 01:27 PM
10/22/16 01:27 PM
Posts: 528 SW CO
HemiSportFury
SW CO
RR has been nothing but a straight up guy who has contributed a lot to this site. I feel it is out of line for the two of you to question his integrity. If you don't like the post, don't open it, No need to attack him X2
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: HemiSportFury]
#2180314
10/22/16 01:55 PM
10/22/16 01:55 PM
RapidRobert
I (very much) appreciate the backup guys, & you know as much time as I spend on here I've noticed that some people tend to wake up more foul on the weekend (I ain't sure why!) but I have seen it. When the time comes not sure If I can take pics or even if pics will be needed/applicable as it will depend on what it ends up being but when I know you will know
[Re: HemiSportFury]
#2180351
10/22/16 03:17 PM
10/22/16 03:17 PM
Posts: 10,704 North Dakota
6PakBee
North Dakota
RR has been nothing but a straight up guy who has contributed a lot to this site. I feel it is out of line for the two of you to question his integrity. If you don't like the post, don't open it, No need to attack him X2 X3
[Re: Stroker]
#2180524
10/22/16 09:52 PM
10/22/16 09:52 PM
RapidRobert
Didn't anybody see wingman's little smiley at the end of his post? I did miss that!
