Page 6 of 6 1 2 3 4 5 6
Re: How to block off heat riser ports-*DONE* [Re: aarcuda] #2159592
09/22/16 06:48 PM
09/22/16 06:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Do as I suggested earlier and mill a recessed area around the port for the plates to sit in. shruggy That's probably more expense then what you want to spend though. My father-in-law has a mill in his garage. I've thought about having him do what I suggested. It would be pretty easy to do. Then if the plates sit a little lower then the flange, you could smear some high temp silicone over them. That might insulate them from the heat and extend their life expectancy.
Re: How to block off heat riser ports-*DONE* [Re: aarcuda] #2159621
09/22/16 07:46 PM
09/22/16 07:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Is there a reason NOT to simply use the Fel-Pro 1215 pan that has the ports blocked off? That's what I've been doing for over 20 years.
https://www.summitracing.com/parts/fel-1...CFYdsfgodva4DKg
Re: How to block off heat riser ports-*DONE* [Re: aarcuda] #2159623
09/22/16 07:48 PM
09/22/16 07:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I would just redo the weld job on the intake manifold.
I usually set the piece to block off the flow below the sealing surface and have it welded in there. That way when/if the manifold gets milled most of the weld remains untouched.
Re: How to block off heat riser ports-*DONE* [Re: Pacnorthcuda] #2159724
09/22/16 10:20 PM
09/22/16 10:20 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Kinda difficult to make that fit a small block I'd guess?
Re: How to block off heat riser ports-*DONE* [Re: aarcuda] #2159730
09/22/16 10:28 PM
09/22/16 10:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
On my LA's I just fill the crossover port about 1/2" in the intake with JBWeld. Never had a problem.
Don't be the exception.
Re: How to block off heat riser ports-*DONE* [Re: J. Hammer] #2161944
09/26/16 12:36 PM
09/26/16 12:36 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
LOL! yes, I have a small block and that valley pan wont fit
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
