Re: Hemi engine serial number
[Re: BS27ROB]
#215787
02/06/09 09:59 PM
02/06/09 09:59 PM
When was the engine serial number stamped? When the long block was assembled, or when it was dressed and test run? The 10,000 day number is 3040 (Nov 23). Should carbs, dist, manifolds, etc. all predate this date?
It sounds to me like you are asking about the ENGINE plant assembly serial number NOT the assembly date found up by the water pump. I think that the first was t5he bare long block with exhaust manifolds, intake and possibly carbs. I think the other date is stamped at the time of INSTALL with other items such as alternator, etc.
I am not sure but would like to hear something with some factory back up regarding this.
