distributor advance springs...Options?
#2157204
09/19/16 02:24 AM
09/19/16 02:24 AM
Posts: 516 ND
dodgedon
ND
I would like to fine tune the mechanical advance on my truck, 85 360 in a W350 crew cab. I'm thinking "All In" around 3000 RPM. Currently it seems to be about 4000 RPM. What spring/springs would get me in the ball park? I know this could be some trial and error. Stock distributor, Would just the one light spring get me close? Or some other combination???? Thanks for any ideas.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
Re: distributor advance springs...Options?
[Re: dodgedon]
#2157208
09/19/16 02:55 AM
09/19/16 02:55 AM
RapidRobert
I would set the initial with the vacuum gauge method or to 15-18 would get you close then shorten the slots to get 35 total (initial+slots) & the $22 FBO plate is the fastest/easiest/cheapest way to accomplish this then toss the one heavy spring with the elongated loop on one end & sub in a mr gasket 925B or MP light spring in its place for a start keeping the OE light spring. any combo of one or two springs will let the weights advance in a linear rate. here's a chart tho the crane kit is no longer available there are chebby and hardware store springs that can be subbed in. always keep the OE light spring. you want to be close to the pinging point but never over it. you also do not want the advance to start any less (point X) than 100-200 RPM above the hot in gear idle speed which is what you will see at the stoplight. EDIT (1) mr gasket 925B spring will give you full advance at ~1200 RPM and both of em at ~2400 RPM
[Re: RapidRobert]
#2157214
09/19/16 03:30 AM
09/19/16 03:30 AM
Posts: 516 ND
dodgedon
ND
thank you for the chart. That helps to know what to expect from some of the options out there. I didn't think about trying 2 light OEM springs. As for timing I'm currently at 18 initial and 16 in the plate. This was a surprise as I've always found too much in the plate.
[Re: 71birdJ68]
#2157286
09/19/16 11:46 AM
09/19/16 11:46 AM
crabman173
crabman173
FBO plate is da Bomb! Best part available for Mopar market--easy as pie
[Re: dodgedon]
#2157369
09/19/16 01:42 PM
09/19/16 01:42 PM
RapidRobert
As for timing I'm currently at 18 initial and 16 in the plate. This was a surprise as I've always found too much in the plate. You might wanna give it a visual just to confirm everything is copacetic in there as 2 common slot lengths are stamped 11 & 17 (22 & 34 on the crank). the 11 is ~.406" and the 17 is ~7/16 (.4375")
[Re: Supercuda]
#2157401
09/19/16 02:21 PM
09/19/16 02:21 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
This is a great bargain and not just because I have used one in a friends bracket race 360 Dart Sport. As I recall it comes with 3 sets of springs in various strengths.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: dodgedon]
#2157585
09/19/16 06:03 PM
09/19/16 06:03 PM
Posts: 5,162 CT
GTX MATT
CT
I would like to fine tune the mechanical advance on my truck, 85 360 in a W350 crew cab. I'm thinking "All In" around 3000 RPM. Currently it seems to be about 4000 RPM. What spring/springs would get me in the ball park? I know this could be some trial and error. Stock distributor, Would just the one light spring get me close? Or some other combination???? Thanks for any ideas. Yes it will
[Re: RapidRobert]
#2157720
09/19/16 09:12 PM
09/19/16 09:12 PM
Posts: 516 ND
dodgedon
ND
As for timing I'm currently at 18 initial and 16 in the plate. This was a surprise as I've always found too much in the plate. You might wanna give it a visual just to confirm everything is copacetic in there as 2 common slot lengths are stamped 11 & 17 (22 & 34 on the crank). the 11 is ~.406" and the 17 is ~7/16 (.4375") Yes, I would agree with you. Like I said I was "surprised" I have not looked into this one yet. I did open another that i had here from a truck and the slots were .375. It was stamped 76 ??
[Re: DrCharles]
#2157771
09/19/16 10:24 PM
09/19/16 10:24 PM
RapidRobert
No I dont have a specific recommendation but as you know it'd take something stiffer than what is in the chart then work with when it maxes out. point X is the most important (when it starts). it's gonna take alot of trial and error and grinding the tips of the weights to fine tune is an option in addition to springs. the MP/transdapt/mr gasket spring kits only have (1) pair of springs each & they are very light. EDIT I would call Don at FBO & find out if any of the springs in his (3) piece spring kit with the OE light spring or a combo of his springs will give you a point X at 1200 or above for your needs. MORE EDIT I ain't tried this yet (just thinking out loud) but I'm thinking a person could drill the weights & melt in lead to increase the rate. SB & BB weights are different & the SB ones look like a comma at the beginning of a sentence and BB, the ones at the end of a sentence. MORE EDIT the heavy OE spring with the elongated loop on one end, a person could cut/rebend that loop to make a "regular" spring out of it, it is heavy tho
[Re: RapidRobert]
#2161181
09/25/16 02:13 AM
09/25/16 02:13 AM
Posts: 516 ND
dodgedon
ND
I had a chance to look into this today. Just wanted to thank Rapid Robert for the chart he posted. I used two stock light springs and ended up just what i wanted on the first try. This distributor also had a short slot .380 "in the plate". So with my 18 initial, I ended up at 35 degrees right at 3000 RPM.
Dr. Charles... I can tell you that with what I used, I still had 18 degrees at 1500 RPM. The stock setup i was up to 21 at 1500 RPM. It would seem that the stock heavy spring with the long loop lets the weights take off quicker (advance), but then hold it back later. The two stock light springs hold the weights a little bit, but then advance quicker... Hope this helps
[Re: dodgedon]
#2161202
09/25/16 03:32 AM
09/25/16 03:32 AM
RapidRobert
I used two stock light springs and ended up just what i wanted on the first try. when did the advance start? I wanna compare that to the chart, showing 900 there
[Re: dodgedon]
#2161288
09/25/16 11:46 AM
09/25/16 11:46 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Dr. Charles... I can tell you that with what I used, I still had 18 degrees at 1500 RPM. The stock setup i was up to 21 at 1500 RPM. It would seem that the stock heavy spring with the long loop lets the weights take off quicker (advance), but then hold it back later. The two stock light springs hold the weights a little bit, but then advance quicker... Hope this helps Thanks. If I'm reading this right, you had two light springs and no advance (18 initial) at 1500? The loop in the heavy spring actually keeps the spring from providing any tension at all, until the weights have moved out some under control of the other spring. From what I've read it's really slow advance once it kicks in (just a couple degrees up to 5000) because it's so stiff. Don at FBO suggested I start with the two silver springs (from his kit) and see how it goes. I think they're the stiffest of the three pairs he provides.
[Re: DrCharles]
#2161421
09/25/16 03:33 PM
09/25/16 03:33 PM
Posts: 516 ND
dodgedon
ND
Yes that is what i'm trying to say. I had 18 at idle and at 1500 rpm. At 2000 it was 26 degrees. So some time between 1500 and 2000 rpm is when it started to advance. 2500 rpm 28 degrees, 3000 rpm 35 degrees.
I should add that these two light springs didn't look exactly the same. But they came out of stock 81 and 85 truck small block distributors.
