'72 Roadrunner headliner #215424
02/05/09 11:22 PM
02/05/09 11:22 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
The headliner on the roadrunner we are restoring was already removed prier to purchase and I was wondering how to find out whether I need a 4-bow or 6, I have 4 long rods and 2 short ones that aren't long enough to reach side to side almost look like they hang in the middle maybe? Was there any method as to what cars recieved 4 or 6? Thanks for the help!
Re: '72 Roadrunner headliner [Re: indytex96] #215425
02/06/09 10:31 AM
02/06/09 10:31 AM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
Re: '72 Roadrunner headliner [Re: indytex96] #215426
02/06/09 10:32 AM
02/06/09 10:32 AM
Re: '72 Roadrunner headliner [Re: indytex96] #215427
02/06/09 01:34 PM
02/06/09 01:34 PM
Shoreline, Washington
72roadrunnergtx Offline
4-bow in 72’, two small wires position the rear most rod and clips to the rod and into the inner roof support above the back glass. You should have two oval shaped holes in the support about 18”or so either side of the car’s centerline.
about in this location
Re: '72 Roadrunner headliner [Re: 72roadrunnergtx] #215428
02/06/09 02:00 PM
02/06/09 02:00 PM
SE Kansas
I
I
SE Kansas
Thank you for great info with a picture to boot! Now if it would install itself...
Re: '72 Roadrunner headliner [Re: indytex96] #215429
02/06/09 02:11 PM
02/06/09 02:11 PM
to bad mick aint still alive..
Re: '72 Roadrunner headliner #215430
02/06/09 02:13 PM
02/06/09 02:13 PM
SE Kansas
I
I
SE Kansas
Your a whole bunch cheaper!
Re: '72 Roadrunner headliner [Re: indytex96] #215431
02/06/09 02:14 PM
02/06/09 02:14 PM
not in the long run.
