Big Block 383 Rebuild questions
#2154220
09/14/16 03:26 AM
09/14/16 03:26 AM
Posts: 6 Germany
FelixM1992
Germany
Hi I'm Felix from Germany I want to swap in my old 383 but first we want to rebuild them We have a set of new Pistons 0030 Original 383 So we think about follow parts Edelbrock 650 cfm Edelbrock Performer air intake Edelbrock Plus Camshaft Original Crankshaft Original Rods Original 906 heads with valve springs from edelbrock Transmission TCI 727 Torque Converter I don't know Rear axle 8 3/4 with 3:23 sure grip Can help anybody me . Thanks Felix
Re: Big Block 383 Rebuild questions
[Re: FelixM1992]
#2154317
09/14/16 12:29 PM
09/14/16 12:29 PM
RapidRobert
Welcome aboard Felix. sounding like a mild daily driver? TCI rebuild kit I am assuming. I would suggest some Stealth aluminum heads as opposed to sinking money into antiquated 906 iron heads. more details: what vehicle, what application, budget. do you already have the 383? better would be a 400 block with an offset ground 440 crank for 470 cubes & the external dimentions would be the same for fitment
[Re: RapidRobert]
#2154391
09/14/16 02:35 PM
09/14/16 02:35 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Welcome aboard Felix. sounding like a mild daily driver? TCI rebuild kit I am assuming. I would suggest some Stealth aluminum heads as opposed to sinking money into antiquated 906 iron heads. more details: what vehicle, what application, budget. do you already have the 383? better would be a 400 block with an offset ground 440 crank for 470 cubes & the external dimentions would be the same for fitment Did you notice he is in GERMANY ??? I agree on not sinking money into those heads , but it may not be an option.
[Re: FelixM1992]
#2154410
09/14/16 02:50 PM
09/14/16 02:50 PM
JohnRR
Everything you have listed is fine to use, do you already have the TCI transmission , if it's just a streetfighter it's nothing special. A basic rebuild with stock type parts and a shift kit, you pay the big bucks because you are paying for their race sponserships.
[Re: FelixM1992]
#2154477
09/14/16 04:37 PM
09/14/16 04:37 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
You really need to look at the pistons and heads to make sure you have enough compression. Some 383 pistons will give you extremely low compression especially on a 906 head.
Don't ask me how I know........
[Re: markz528]
#2154507
09/14/16 05:39 PM
09/14/16 05:39 PM
Posts: 1,603 Central Ohio
BMChrysler68
Smarter than the average bear? I think not.
Central Ohio
Agreed. You can overcome some of this with a cam that has a more aggressive lift rate. I think there are better options out there than that Performer RPM cam if you're using some ~8:1 Speed Pro flat tops. The Comp XE268 will work with power brakes and a stock converter. It will also preserve some of the low end you'll be giving up with the loss in compression.
1968 Plymouth Fury III 2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon 360-4v, automatic
2014 Challenger R/T Classic 6-speed
[Re: FelixM1992]
#2154512
09/14/16 05:47 PM
09/14/16 05:47 PM
JohnRR
I bought this set in summit Federal Mogul Premium Engine Rebuild Kits MKP-667E300 here is the part number I don't have any transmission for it . You can watch on summit thank you for your help You don't want that kit , if you have not bought it yet don't, it uses this piston which will give you barely 8.0 compression . https://www.summitracing.com/parts/slp-366ap30383 piston selection is horrible, the stock piston in the 69 383HP is .0025 in the hole , with the stock 906 the compression is barely 9.2 , not the 10.0 that chrysler rates it at. The TCI transmission is grossly overpriced for what you are getting, don't waste you money on it either. Contact John Cope/CRT and see what he can do for you .
[Re: FelixM1992]
#2154523
09/14/16 05:58 PM
09/14/16 05:58 PM
BMChrysler68
Central Ohio
The OP mentions money being a determining factor in the short term. That engine kit will get the car on the road inexpensively even if it isn't an ideal piston. Based on the parts list, I'm inferring a slightly warmer street engine is the goal. That can definitely be accomplished with smog pistons assuming the OP picks a cam that makes the most of cylinder pressure--and octane rating will be a complete non-issue.
[Re: JohnRR]
#2154685
09/14/16 09:32 PM
09/14/16 09:32 PM
dogdays
No way is a Comp XE268 the right cam for an 8:1 383. The largest cam I'd say fit the bill would be Nughes SEH1016BL-12 http://www.hughesengines.com/Index/produ...mp;partid=30251Or Lunati Voodoo cam 10230700 Or Comp XE256H 21-221-4 Another thing is compression: Don't put a lot into the 906s right now, the Edelbrock E-Street heads at 75cc will put the engine right at 9.0:1. R.
[Re: FelixM1992]
#2155011
09/15/16 11:55 AM
09/15/16 11:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Is that budget entirely for the engine build? Because that works out to a max of about $9000 US.
Which is a lot of money for a 383 rebuild.
I don't know what pr9cves are like in Europe but that would be a monster build here. A complete 440source stroker kit is $2249, rods, pistons, crank, bearings all balanced and ready to install,.
Another $1000 gets you a pair of all new aluminum cylinder heads.
That's less than half your budget and most of the hard parts done and new.
[Re: cudaman1969]
#2155080
09/15/16 01:48 PM
09/15/16 01:48 PM
JohnRR
How good is the gas in Germany? 906 heads are fine, tons of race engines used these heads and did fine. Don't go over board on the cam, takes away drivability. Most here on Moparts will have you building a $50,000 race engine to putt around on the street. Keep it simple, you'll be fine with what you got. Good luck on your endeavor. Let us know how it works out. Mike Yes 906 heads are fine, but not with a piston that is speced to be used with a 516 sized/shape combustion chamber. Tons of race engines USED them because they were all they had to use, or the class specified them, otherwise they are a POOR choice, especially in a 383 that is hard to build compression in to begin with. I just did the math, 90cc head, .041 gasket that is in the kit he bought, a piston .087 in the hole on a blueprint block (1.848 ch), his block may be a little taller, 7.52 compression ...
[Re: JohnRR]
#2155138
09/15/16 03:19 PM
09/15/16 03:19 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
How good is the gas in Germany? 906 heads are fine, tons of race engines used these heads and did fine. Don't go over board on the cam, takes away drivability. Most here on Moparts will have you building a $50,000 race engine to putt around on the street. Keep it simple, you'll be fine with what you got. Good luck on your endeavor. Let us know how it works out. Mike Yes 906 heads are fine, but not with a piston that is speced to be used with a 516 sized/shape combustion chamber. Tons of race engines USED them because they were all they had to use, or the class specified them, otherwise they are a POOR choice, especially in a 383 that is hard to build compression in to begin with. I just did the math, 90cc head, .041 gasket that is in the kit he bought, a piston .087 in the hole on a blueprint block (1.848 ch), his block may be a little taller, 7.52 compression ... He's got a 383 not a multi dollar blown Hemi. What he's got will make a good street engine for the money he's ALREADY spent. What ever we spend for the good heads here in the states, double that for him over there.
[Re: FelixM1992]
#2155143
09/15/16 03:37 PM
09/15/16 03:37 PM
JohnRR
I'm not saying he needs to spend millons on a head, it is what it is.
Are you ASSuMEing he has a super duper PORTED head off someones race engine? In stock form a 383, in a car weighing almost 4000 lbs, overcammed is going to be less than impressive, especially with 7.5 compression...
Hopefully joining that group SuperRob mentions will garner him some help , hopefully parts wise and finding a capable shop that can build that engine right.
[Re: FelixM1992]
#2155294
09/15/16 08:15 PM
09/15/16 08:15 PM
Posts: 20,897 A collage of whims
topside
A collage of whims
For a street 383 in a fairly heavy car, been there & done that, and here's what I'm thinking given what Felix has told us so far: You can either return the piston kit and get one with more compression from the same source, or look at 440source.com and see what they have. A cast piston will be fine but forged holds up better to detonation. Not knowing the octane ratings in the Fatherland, I wouldn't want to go more than 9.0:1 on an iron-head Wedge @ 91-92 octane. The Edelbrock cam is kinda short on lift, but IF you also need rocker arms, a 1.6 ratio would help that. Otherwise, look at more modern stuff like the various Comp Cams, Engle choices. Something in the 214-224 @ .050 and around .450-.480 lift will be mild enough for a stock converter at 9.0:1 CR. I've used as much as .504 lift at that duration with tall gears & stock converter and had very nice street manners. With old stock heads & block, a surface cut is likely needed for flat decks on both. Good machine work, balancing, and a good valve job go a long way; find a GOOD machine shop that's familiar with American engines and has an eye for details. There's maybe .5 CR there without going nuts. I like double springs on the valvetrain, and at least a windage tray. Use a dual-plane intake (look in the ads here for nice used), and a 650CFM carb would be adequate. The Eddy & Stealth heads I've used all needed a better valve job, and the springs & parts were OK.
[Re: topside]
#2155607
09/16/16 11:18 AM
09/16/16 11:18 AM
Posts: 178 Hamburg - Germany
SuperRob
Hamburg - Germany
Not knowing the octane ratings in the Fatherland, I wouldn't want to go more than 9.0:1 on an iron-head Wedge @ 91-92 octane. Gas stations max out at 95 octane (called ultimate102 over here).
[Re: SuperRob]
#2155645
09/16/16 12:09 PM
09/16/16 12:09 PM
JohnRR
Not knowing the octane ratings in the Fatherland, I wouldn't want to go more than 9.0:1 on an iron-head Wedge @ 91-92 octane. Gas stations max out at 95 octane (called ultimate102 over here). If he could find even a set of 516 heads over there those with a little porting and 1.74 valves that would be better than the 906's , but he would need to get a piston that is closer to zero. DO NOT HACK .087 off the deck to get those pistons at zero , it would be cheaper to just buy another set of pistons from summit and have them shipped over. Which wouldn't be a bad idea,in the long run that will save him money.
[Re: FelixM1992]
#2155688
09/16/16 01:29 PM
09/16/16 01:29 PM
RapidRobert
i dont want a race engine i want a little more than the original engine was. I would go with a dual plane intake & a fairly small carb possibly one of the newer ones that all the metering systems are adjustable. Holler what parts you go with & how it turns out (if it meets your expectations)
[Re: FelixM1992]
#2155742
09/16/16 02:29 PM
09/16/16 02:29 PM
markz528
Morrow, OH
I just went through this on my 67 383. I bought KB pistons and on paper I was to be at 9.0:1 compression. Measured came in at 8.2:1 and I cried.
I fortunately was able to recover by milling the 915 heads 0.040 inches and that got me to around 8.9:1 (from what I recall - could be a tad less). But that was with a closed chamber head - the open 906 head puts you in a much worse position.
[Re: FelixM1992]
#2157547
09/19/16 05:07 PM
09/19/16 05:07 PM
Posts: 43 League City, TX
BlueGhost
League City, TX
If you haven't rebuilt your heads yet, you might consider the Edelbrock E-Street heads. The 75cc e-streets, part # 5090, are around $1300, available trough Summit, and would bring compression up to 8.5:1.
1958 Plymouth Suburban
