Correct way to raise the back end?
#2153975
09/13/16 09:05 PM
09/13/16 09:05 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I admit I like the 70's raised back end look, but I don't want to achieve it at a large sacrifice to handling. Usually I see this accomplished through really tall spring hangars and air shocks. I just did a spring relocation and a mini tub, and put in the MP XHD springs. Unfortunately, the springs sit way lower than I had hoped. With a 15x10 wheels, and a mild 500ish hp 440, I don't want to much tire for the engine, so I think I should stick with 28's for now. What I'm getting at is the back end doesn't sit as high as I like. Is there any way to get it higher without changing the springs? I'd like to stay away from pump up air shocks
Re: Correct way to raise the back end?
[Re: Adam71Charger]
#2153992
09/13/16 09:28 PM
09/13/16 09:28 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I admit I like the 70's raised back end look, but I don't want to achieve it at a large sacrifice to handling. Usually I see this accomplished through really tall spring hangars and air shocks. I just did a spring relocation and a mini tub, and put in the mp Che springs. Unfortunately, the springs sit way lower than I had hoped. With a 15x10 wheels, and a mild 500ish hp 440, I don't want to much tire for the engine, so I think I should stick with 28's for now. What I'm getting at is the back end doesn't sit as high as I like. Is there any way to get it higher without changing the springs? I'd like to stay away from pump up air shocks i don't think there is any other way except to re-arch your springs. longer shackles maybe but they look goofy
[Re: ahy]
#2154108
09/13/16 11:54 PM
09/13/16 11:54 PM
RapidRobert
this might be a stretch but would it be feasable to lower the front 4 hole and the rear 2 hole rear mounting points with some welded stock? I think that would at least keep the rate the same. However which way you achieve your goal I would check the ujoint angles when done. for sure no air shocks
[Re: Adam71Charger]
#2154136
09/14/16 12:35 AM
09/14/16 12:35 AM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Air shocks get a bad rap... and probably for good reason in Mopar circles. They work just fine in most cases but Mopars just don't have upper shock mounts strong enough to handle the extra stress. Especially when the metal is 50+ years old. I'm building a 426 Street Wedge recreation and back in the day the owner would have used air shocks or shocks with helper springs to get the stance he wanted. To solve this weakness problem, I added a piece of 2"x 2"x .120 wall square tubing as an integrated crossmember to supplement the stock shock mounts. Admittedly it would have been a difficult job if the car hadn't been on a rotisserie. Bottom line: this will add enough strength to the mounts that I won't have to worry about ripping them out with air shocks.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Adam71Charger]
#2154302
09/14/16 12:05 PM
09/14/16 12:05 PM
Centerline
Texas Hill Country
Nice mod centerline. Now that you guys mention it, I remember being bewildered when we had the rear out to do the mini tub. I couldn't believe how flimsy the shock mounts were, it was like floor pan thickness at most. I did weld on some thick washers to the mount holes which had become elongated Yea, the mounts themselves are made of pretty thick material but they're spot welded to maybe 18 ga. sheet metal. When I did my mod I perimeter welded each mount to the square stock just to make sure they wouldn't pull away.
[Re: Adam71Charger]
#2154392
09/14/16 02:38 PM
09/14/16 02:38 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I admit I like the 70's raised back end look, but I don't want to achieve it at a large sacrifice to handling. Usually I see this accomplished through really tall spring hangars and air shocks. I just did a spring relocation and a mini tub, and put in the mp Che springs. Unfortunately, the springs sit way lower than I had hoped. With a 15x10 wheels, and a mild 500ish hp 440, I don't want to much tire for the engine, so I think I should stick with 28's for now. What I'm getting at is the back end doesn't sit as high as I like. Is there any way to get it higher without changing the springs? I'd like to stay away from pump up air shocks You've already compromised the handling by moving the springs inboard, raising like we did back then is only going to make the handling worse ... Good luck in your quest.
[Re: dogdays]
#2154935
09/15/16 06:38 AM
09/15/16 06:38 AM
Adam71Charger
Whatever you end up doing, try to keep the front and rear pivot points at the same relative height from the ground. Change the relationship too much and you get into self-steering effects. For example, my '64Dog rear was set up, stock, so that when the vehicle tilts one way, the rear end steers in the same direction. It isn't much when unloaded, but I do a lot of mountain driving and having the rear start steering itself towards the outside of a curve is kind of spooky.
R.
Dogdays, can you elaborate for me, I'm not fully understanding the pivot points. Do you mean the the height off the ground the front and rear of the springs attaches to the frame?
[Re: Adam71Charger]
#2155122
09/15/16 02:55 PM
09/15/16 02:55 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Redrill the front mount to lower the bolt hole, that will raise the the rear of the car up. The lower the hole to the bottom of the mount the higher the rear of the car will be raised You can test that by using a block of wood as a spacer between the top of spring eye and the inside of the mount with the bolt removed
[Re: Cab_Burge]
#2155193
09/15/16 05:00 PM
09/15/16 05:00 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Redrill the front mount to lower the bolt hole, that will raise the the rear of the car up. The lower the hole to the bottom of the mount the higher the rear of the car will be raised You can test that by using a block of wood as a spacer between the top of spring eye and the inside of the mount with the bolt removed I built my own front spring mounts when I narrowed the rear on my '68 Coronet bracket car. They were boxes that I welded into the subframe with four sets of holes for the front spring mount. I had planned to use the SuperStock springs so the front sets were for the stock length springs and the rear sets were for the shorter SS springs. I drilled each pair with a lower and an upper mount. Actually the car hooked so well that I stuck with the stock springs. The Ramcharger is going to get rollers in the back to keep it low. On the subject of ride height, I went for a ride yesterday with a friend in his '36 Plymouth street rod that is low and far from slow. It handled like a go-kart on steroids, that was fun!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Adam71Charger]
#2156195
09/17/16 12:40 PM
09/17/16 12:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There is no "correct way" to raise your back end.
Because raising the back end is never optimal in a car.
It shifts the weight forward, lessening traction and braking.
It raises the CG, making handling worse.
When I see a car with it's rear jacked up it tells me musclecar equivalent of a ricer.
[Re: Supercuda]
#2156259
09/17/16 02:28 PM
09/17/16 02:28 PM
RapidRobert
It raises the CG, making handling worse. I would agree. Adam you have relocated/minitubbed. you are on the right track
[Re: Supercuda]
#2156269
09/17/16 02:55 PM
09/17/16 02:55 PM
DaytonaTurbo
Manitoba, Canada
Don't care, cars like mine look terrible at stock rear ride height. Like an old granny with a dragging ass. It was done 20 years ago so I couldn't tell you. A 28" tire fully clears the rear wheel well lip in terms of height.
[Re: Supercuda]
#2156698
09/18/16 10:44 AM
09/18/16 10:44 AM
Posts: 19,355 north of coder
moparx
There is no "correct way" to raise your back end. why sure there is ! way back in the day, "fearles frankie", a local "muscle car ricer" had a 65 or so mustang with a real fast [ ] v8 3speed ! only problem was, he couldn't blaze the tires like the rest of his tribe on the street, and he didn't have money for air shocks. but he got a brilliant idea ! he jacked up his beast until the rear was off the ground and the springs had a real good arch to then. next, he cut up two 6x6 wood blocks just a tad longer than the distance between the axle tubes and the floor pan, wedging them between said distances with a sledge because they were longer than necessary and he didn't want them to fall out ! a little flat black rattle can poofery, and wow ! looked just like "hi-jackers" with 175lb. air in them ! went out cruising friday night, and when he showed off his new stance, well, by golly, we was sure 'nuff impressed and congratulated him for what a kewl badass hotrod he now had ! he said it really "improved" his horspower, because he could now blaze the tires almost forever ! after a little goading, [well not really] he was gonna show us. out on the street, one, two, three, and he is off...... tires just a boiling smoke [7.75x14" size on chrome-ina-can wheels]. boy was us guys impressed ! "fast frankie" blasted past under the interstate bridge where the locals made their "quota" for the city. "fast frankie" got an invitation to the "policeman's ball" with a slight twist added. seems the officers ordered him to let the air out of his shocks, but then found out about his lift kit. frankie had to have his car towed. those of us there that night still chuckle when this incident is brought up !
[Re: Adam71Charger]
#2156701
09/18/16 10:46 AM
09/18/16 10:46 AM
Supercuda
About to go away
About to go away
up yours
Well, at least he fixed the wheel hop issue early Stangs had, lol.
[Re: Adam71Charger]
#2156888
09/18/16 05:26 PM
09/18/16 05:26 PM
Supercuda
About to go away
About to go away
up yours
Why are you bashing those of us that are pointing out the issues of raising the rear end. Can you read the OP's mind to know that he's aware of it?
[Re: mikemee1331]
#2156902
09/18/16 05:51 PM
09/18/16 05:51 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
why the bashing from some of you? the op asked how to do it correctly without ripping his cross member out with air shocks not if raising it is correct. those of us that like the look would like to know how others of 'us' have done it. Because back in the day this was usually only used to put WAY TOO big of a wheel and tire combo on a car and always looked "jimmy rigged"..... The wheel options and multiple back spacing options today make no sense to do that anymore That said, if that's what the OP likes, more power to him.. BUT, just like 45 years ago, be prepared for some not very flattering comments about it...
[Re: Supercuda]
#2156912
09/18/16 06:10 PM
09/18/16 06:10 PM
mikemee1331
bethlehem pa
this is helpful. Because raising the back end is never optimal in a car.
this is bashing "When I see a car with it's rear jacked up it tells me musclecar equivalent of a ricer." the OP didn't ask "what's your opinion on the look". he likes the look, i like the look and so do many of us. for the 800-1000 miles i put on my car a year i'll sacrifice some handling and a few worn idler arms.
[Re: Adam71Charger]
#2157687
09/19/16 08:32 PM
09/19/16 08:32 PM
Centerline
Texas Hill Country
Raising the rear, back in the day was done to fit drag slicks inside the wheel wells. However, racers knew how it shifted the weight forward so they would raise the front to compensate. This is an example of what was done back then. The car has a classy rake and still drives, stops, and handles well. Now days, with front and rear IFS raising the car isn't as easy or necessary. Those of us who lived through that period still like the raked look though.
[Re: Adam71Charger]
#2157776
09/19/16 10:28 PM
09/19/16 10:28 PM
Posts: 4,848 Memphis
HemiRick
Memphis
This is where to start w this quest.
Just mount bigger tires. The rake some still seem to like will follow.
At least with the big rear tires there's some legitimate reason for the stance.
Doing nothing but this to my Challenger makes all the diff. in the world. Here's a pic of the sig challenger w bigger rear wheels and tires
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2157808
09/19/16 11:12 PM
09/19/16 11:12 PM
mikemee1331
bethlehem pa
the thing with the e-bodies is the rake look is built in they have the upward swoop at the rear. i don't think anybody is looking for that 'clown-high' look like with the old N-50 series rear tires. this is mine with the rake i like. the back sits at 23". the back is raised so my tires don't rub when i corner. the car is tubbed but i run a 29x15x15 in the back.
[Re: mikemee1331]
#2157820
09/19/16 11:24 PM
09/19/16 11:24 PM
Supercuda
About to go away
About to go away
up yours
this is bashing "When I see a car with it's rear jacked up it tells me musclecar equivalent of a ricer." the OP didn't ask "what's your opinion on the look". he likes the look, i like the look and so do many of us. for the 800-1000 miles i put on my car a year i'll sacrifice some handling and a few worn idler arms. So, exactly, how would this wear out idler arms? I know I never said anything about that so it must be something you believe.
[Re: Supercuda]
#2158245
09/20/16 07:38 PM
09/20/16 07:38 PM
mikemee1331
bethlehem pa
this is bashing "When I see a car with it's rear jacked up it tells me musclecar equivalent of a ricer." the OP didn't ask "what's your opinion on the look". he likes the look, i like the look and so do many of us. for the 800-1000 miles i put on my car a year i'll sacrifice some handling and a few worn idler arms. So, exactly, how would this wear out idler arms? I know I never said anything about that so it must be something you believe. not 'believe' but told by the state inspections dude back in my youth. made sense given the number of idler arms i went through in my first RR. a couple of other unconfirmed things i was told way back then smoking dried banana peels will get you high. could never get them to light BUT i can confirm that the sulfur fumes from all the matches will get you dizzy and incredibly sick to your stomach. touching yourself in an unholy way will make you go blind. at 62 i'm still ok but i'm working on this one
