1970 Electronic Voltage Regulator #2152521
09/11/16 07:39 PM
09/11/16 07:39 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
What year regulators had the small dime size dimple next to the terminals? Have 2 dated 329 which I figure means 32nd week of 1969.
Re: 1970 Electronic Voltage Regulator [Re: formula_s] #2153204
09/12/16 06:22 PM
09/12/16 06:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think that ended at the end of the 71 model, but I'm not sure? You thinking about buying one?
Re: 1970 Electronic Voltage Regulator [Re: 71birdJ68] #2153715
09/13/16 02:42 PM
09/13/16 02:42 PM
North Pole,New York
North Pole,New York
Already have two .I was just thinking about that small bump that's not seen on many high $$ restored cars.
Re: 1970 Electronic Voltage Regulator [Re: formula_s] #2153724
09/13/16 02:52 PM
09/13/16 02:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have three NOS ones, two Mopar, and one Nehof, and can't use them cause they over charge. The repo batteries can't handle over charging. So I took a new one that works as it should and made a bump on it and had it stamped with the correct stamp. I guess 40 years of setting on a shelf takes a toll on them.
