2 speed wiper resistor value? #215312
02/05/09 08:11 PM
02/05/09 08:11 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
I just restored my wiper motor and wanted to make sure that the low speed resistor is good. I measured it to have .5 ohms and I want to know what the spec is on this piece. If this is out of spec, where can I buy just a new resistor? Thanks for your help!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: 2 speed wiper resistor value? [Re: itali83] #215313
02/05/09 09:28 PM
02/05/09 09:28 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I wouldn't worry about the actual resistance value that much..
The problem would be if the resistor is open..
ie.. no resistance
Just my ...
