Dual vs Single plane intake?
#215167
02/05/09 05:13 PM
02/05/09 05:13 PM
Forgive my ignorance, what is the difference between these two intakes and what would be better for a stock motor? (440)
Re: Dual vs Single plane intake?
[Re: topside]
#215170
02/05/09 06:11 PM
02/05/09 06:11 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
"Plane" refers to levels of intake runners; a single-plane has all the runners at the same height, feeding from the plenum area under the carb at the same height. They'll have a plenum that is not as deep as an equivalent dual-plane intake. A dual-plane has the runners at different levels - on a V8, four at the higher level & 4 at the lower - which feed from the plenum in basically a 2-story architecture. Generally a dual-plane will have longer runners that curve more than the single-plane, whose runners are shorter & more direct. Single-planes tend to be taller at the carb mounting flange. Dual-planes tend to make more bottom-end & midrange power than single-planes, which are generally biased more towards higher-RPM power. For an engine operating under say 5000 RPM, and anything "stock", I'd go with a dual-plane.
You got your planes mixed up,this is a plane!
[Re: 62maxwgn]
#215171
02/05/09 07:00 PM
02/05/09 07:00 PM
Posts: 6,516 Santa Cruz, California
Lefty
And that's the plane truth Ruth!
#215175
02/06/09 01:00 PM
02/06/09 01:00 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
There are good intakes for a STOCK motor in both designs ....
Single plane ? ... Streetmaster.
Dual plane ? .. SP2P.
