Page 3 of 4 1 2 3 4
Re: How much are my small headers killing my performance [Re: cudaman1969] #2150692
09/08/16 10:50 PM
09/08/16 10:50 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It Was the Engine Masters show Episode 4 Episode 12 is the followup.
Re: How much are my small headers killing my performance [Re: cudaman1969] #2150735
09/08/16 11:28 PM
09/08/16 11:28 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Originally Posted By cudaman1969
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO
That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference.
I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it.
153 mph @ 3280lbs this motor is legit it has the best of everything on it
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150788
09/09/16 12:41 AM
09/09/16 12:41 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Are you runing the same converter, trans gearing, and rear gear he did?
Re: How much are my small headers killing my performance [Re: slantzilla] #2150801
09/09/16 01:06 AM
09/09/16 01:06 AM
CEDAR RAPIDS
CEDAR RAPIDS
no,no,no all I'm wondering is if these 1 7/8 headers I'm using are killing my performance and if it would be worth the work to make the larger step headers work !!!
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150868
09/09/16 08:51 AM
09/09/16 08:51 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes.
[image][/image]
Re: How much are my small headers killing my performance [Re: Plymouth340] #2150966
09/09/16 12:38 PM
09/09/16 12:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The moroso chart shows that to be pretty much right on 900hp.
Re: How much are my small headers killing my performance [Re: sgcuda] #2151083
09/09/16 03:01 PM
09/09/16 03:01 PM
CEDAR RAPIDS
CEDAR RAPIDS
Yes I think it will be worth the effort. I've never built headers before but to make these fit shouldn't be that bad I have a tube chassis car there's lots of room. And my time is free
Re: How much are my small headers killing my performance [Re: fast68plymouth] #2151086
09/09/16 03:03 PM
09/09/16 03:03 PM
CEDAR RAPIDS
CEDAR RAPIDS
Yes the power is there. Just seems like something's holding this motor back. I've tried a lot of things and nothing really seems to make much difference so this is my next step
Re: How much are my small headers killing my performance [Re: Plymouth340] #2151216
09/09/16 06:54 PM
09/09/16 06:54 PM
Park Forest, IL
Park Forest, IL
It will be interesting to see if your headers are killing 150 horse.
Re: How much are my small headers killing my performance [Re: Plymouth340] #2151787
09/10/16 07:49 PM
09/10/16 07:49 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
All that header beat up test did was prove that the wrong headers were on the motor to start with....
Re: How much are my small headers killing my performance [Re: Alchemi] #2151799
09/10/16 08:10 PM
09/10/16 08:10 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You need to watch the follow up video. TL/DR answer, no they were the best size.
Re: How much are my small headers killing my performance [Re: fast68plymouth] #2151875
09/10/16 10:07 PM
09/10/16 10:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
At seasons end...... Might be worth a trip to the dyno and see just how much difference in power there is between the headers......before going through the effort of fitting them to the car.
x2
Not only would you find out what the other headers are worth, it could provide more data to help with converter setup.
Re: How much are my small headers killing my performance [Re: Plymouth340] #2152381
09/11/16 02:56 PM
09/11/16 02:56 PM
AndyF Offline
AndyF  Offline
I did a header test on my 470 engine between 2" dyno headers and 1 3/4 stepped to 1 7/8 dyno headers. At 6800 rpm the 2" headers were 10 ft-lbs better.
Re: How much are my small headers killing my performance [Re: Plymouth340] #2152422
09/11/16 04:05 PM
09/11/16 04:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Damn, I'm not so upset with having 1.75 TTI's on my 420 G3 anymore.
Mopar to the bone!!!
Re: How much are my small headers killing my performance [Re: pittsburghracer] #2542525
08/28/18 02:58 PM
08/28/18 02:58 PM
CEDAR RAPIDS
CEDAR RAPIDS
Originally Posted By pittsburghracer
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues
Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet
Re: How much are my small headers killing my performance [Re: Plymouth340] #2542602
08/28/18 04:59 PM
08/28/18 04:59 PM
P
Paul_Fancsali Offline
P
From experience Make sure your tach is accurate. I have seen people going crazy trying to get their car running like it should only to find the tach was 500-600 Rpm slow. For the hell of it try shifting at 8000 or shift when engine sounds right. I was riding in my buddy Demon that was actually slowing down due to over reving cost him bearings I shifted car earlier and surprise the car et went down Have fun!
Re: How much are my small headers killing my performance [Re: Plymouth340] #2542649
08/28/18 06:30 PM
08/28/18 06:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My advice would to be to contact Brett Miller or Ryan Johnson and pick their brains. Both have a lot of high end small block experience. Brett is a walking encyclopedia on small blocks, it blows my little mind everytime I talk with him.
Re: How much are my small headers killing my performance [Re: justinp61] #2542663
08/28/18 07:05 PM
08/28/18 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your not gonna see a 100hp difference from the
set you have on the car to the ones that were
on it.. I was running a W-9 with step headers
(1 7/8-2-2 1/8.. if your conv stalls at 7000 it
is real close I stalled at 5600 and it was a bit
low.. I shifted at 8200 rpm.. it didnt make any
more power when shifted at higher rpms.. I went
up to 9400 and dint do a damn thing
wave
Re: How much are my small headers killing my performance [Re: Plymouth340] #2542989
08/29/18 01:03 PM
08/29/18 01:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What carb(s) are you running............
Re: How much are my small headers killing my performance [Re: Plymouth340] #2543006
08/29/18 01:41 PM
08/29/18 01:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW the smallblock in the heads up car made over 1000 with a set of 1 7/8" 20 long primary headers on the dyno. Headers on the car are 1 7/8 to 2 to 2 /18". Car ran 8.0's last year at 2800.
Page 3 of 4 1 2 3 4
