Re: Starter Relay [Re: Texas383] #2154312
09/14/16 12:21 PM
09/14/16 12:21 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Now you have a bunch of spare relays...if you kept them. Glad you got it figured out.
Re: Starter Relay [Re: Texas383] #2154318
09/14/16 12:31 PM
09/14/16 12:31 PM
Ok.... FINALLY found the culprit. A wire going from the dash to the bulkhead was slightly loose.
that wasn't too difficult now was it!
Re: Starter Relay [Re: Texas383] #2154457
09/14/16 04:02 PM
09/14/16 04:02 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
*in my best Yosemite Sam voice* .... I hate them wires!
Nah.... wasn't too bad at all really. Other than trying to work under the hood and crawl under the dash of a truck that is lifted.
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Starter Relay [Re: Texas383] #2154896
09/15/16 01:43 AM
09/15/16 01:43 AM
I have an 85 ramcharger & no wiring issues but it looks like a nightmare if I did. I'm get out from under it when I get it back running
Re: Starter Relay [Re: Texas383] #2155339
09/15/16 10:06 PM
09/15/16 10:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad to hear you got it fixed. Ron
Re: Starter Relay [Re: 383man] #2156500
09/17/16 11:03 PM
09/17/16 11:03 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lol just went thru all of that on my 66 Belvedere, it was the fusible link wire had separated from the spade fitting, had to reinsert it and solder it .then check depth of the spade into the bulkhead slot...some removal of plastic on the bottom of the outer plug was in order to get correct engagement depth. (it had fried before and i made a replacement fusible link up.
