Page 3 of 3 1 2 3
Re: leaf springs with ladder bars? [Re: emarine01] #214840
02/06/09 11:12 PM
02/06/09 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you wanted to change your system some you could
do like the old pro stockers, they used a leaf and
a bar on top of the axle that acted like a four-link.
I'm sure someone has a pic of that set up
Re: leaf springs with ladder bars? [Re: Sport440] #214841
02/06/09 11:12 PM
02/06/09 11:12 PM
nc
E
emarine01 Offline OP
E
nc
Air bags? like in big trucks , I was just getin lazy , it would be easy to fit something where the shocks mount thats not a coilover but could support the weight , I guess air bags will hold up the truck just havent seen it in racing.
Re: leaf springs with ladder bars? [Re: Quicktree] #214842
02/07/09 12:27 PM
02/07/09 12:27 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
still no body has answered why you would want to set up a modern day race car like this
That car was built in 95, It is just simple, it works. The car would hook at test and tune like it would on raceday. When our competitors were changing 4-link bars, checking how far the zip tie moved up on compression and making shock ajustments we were setting in the trailer talking and having a good time. Low Mantinence! And I know when you get a 4 link car set-up you don't have to mess with it but you don't even have to go through getting it right.
One day I will have something cool here.
Re: leaf springs with ladder bars? [Re: sdaurity] #214843
02/07/09 12:46 PM
02/07/09 12:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oh OK, good to know thats a better set up than a 4 link. heck I may change mine
Re: leaf springs with ladder bars? [Re: dodgedude4x4] #214844
02/07/09 02:04 PM
02/07/09 02:04 PM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Float the front of the ladder bars,
Done it before , works well.......
I seen a stock elim. car set up this way. The back was bolted on to the plate that holds the spring and the front was a pice of tubing that slid inside of anouther tube that was mounted to the front spring eye bolt by 2 clips welded to the outer tube. The stockers have to have a bolton suspention. This car ran 1.30 60s and 10.00 with this setup. On your truck I would think the spring was on tob of the rear, so you would have to find a way to mount it underneath. You might try a leaf link suspention with a bar going from the top of where the rear mounts to the spring to the front frame at the spring mount.
good luck and I did see where you are keeping the springs as per class rules
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: leaf springs with ladder bars? [Re: wildcargo] #214845
02/07/09 03:49 PM
02/07/09 03:49 PM
New Jersey
G&S Perf.Engs. Offline
New Jersey
Hows this for leaf springs & ladder bars car runs 10.60 with a 1.36 60ft.
Re: leaf springs with ladder bars? [Re: G&S Perf.Engs.] #214846
02/07/09 09:31 PM
02/07/09 09:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well, Thats a Great example as to how well leaf springs and ladders can hook.
A 1.36 60 ft. hook should be good for a 10.0 run.
That car is certainly Hooking but not Booking for its 60 ft, ET. Still, Overall not bad IMO. For its ET its a Hook monster, mike
Re: leaf springs with ladder bars? [Re: Sport440] #214847
02/09/09 03:49 PM
02/09/09 03:49 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
I don't see why a floater and a good set of adjustable rancho's wouldnt work great!
Re: leaf springs with ladder bars? [Re: Dustedu] #214848
02/09/09 04:35 PM
02/09/09 04:35 PM
MO
P
psycho_440 Offline
psycho_440  Offline
P
MO
ive got a 78 dodge 4x4 full size. using a ladder bar with a floater and drag shocks it works great in the drags and also in the pits. my bars mount at the center of weight on the truck. it is like the kit from jegs (not the CE kit) but adapted to go over the axle. we also have a truck with the CE kit. i think you can stay lower that way. a few other guys brag how they are running the ladder bar with no floater or slider.... but those trucks wheel-hop like crazy!!! also seen it done with the spring slider but the guy who built mine prefers the floater. i will try to get some pics. BTW your bars look a little short.
Re: leaf springs with ladder bars? [Re: psycho_440] #214849
02/09/09 04:55 PM
02/09/09 04:55 PM
nc
E
E
nc
The bars are 33" we had long bars and had too much lift , I want to keep the front wheels in the mud , wheelies are fun but too hard to recover from if your not dead on, The CE sliders we have arent enough , I will check jeggs for the floater kit thanks
Re: leaf springs with ladder bars? [Re: emarine01] #214850
02/09/09 07:25 PM
02/09/09 07:25 PM
MO
P
psycho_440 Offline
psycho_440  Offline
P
MO
wow!!! wheelies with dot tires??? what you runnin???
Re: leaf springs with ladder bars? [Re: psycho_440] #214851
02/09/09 09:42 PM
02/09/09 09:42 PM
nc
E
E
nc
Its a 84 toyota pickup with a 414 W5 small block
Re: leaf springs with ladder bars? [Re: emarine01] #214852
02/09/09 09:54 PM
02/09/09 09:54 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Wow, what timing. I love the old gassers and just finished building homemade ladder bars for my '63. More for looks than working at the track in my case. I'm sure it is all screwed up but that's because I built em. Mine are 60" long and will mount with a single heim joint under the rear end and another single heim joint under the subframe connectors. All the girder work is just to keep the one pipe from flexing, but more importantly to get the look right. Sure do keep learning a lot from all those who have been here before, thanks. Oh, my rear end housing is under the leaf spring on this car. Kinda like you truck guys. Now I just hope I don't tear stuff apart driving back and forth to work!!!
Re: leaf springs with ladder bars? [Re: jp66charger] #214853
02/09/09 10:27 PM
02/09/09 10:27 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
Leaf springs with ladder bars and floaters can work well. Before re-backhalved my Duster, it was a leaf spring / ladder bar car. Best 60' was 1.35 but the normal was between 1.37 -1.40 depending on weather and track. Ran between 10.05 and 10.20. Won my fair share of races, so it does work. Take some time to get it set up right and test, test and test until you get it where you want. Good luck and have fun!
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: leaf springs with ladder bars? [Re: brktracr] #214854
02/10/09 10:44 AM
02/10/09 10:44 AM
W
wildcargo Offline
wildcargo  Offline
W
Was thinking about this why do you nead the front half of the spring, just put the ladderbars in the front and a leaf from say the back half of the cal track single leaf spring and a watts link or a diagnal link.
So what you think
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
Re: leaf springs with ladder bars? [Re: wildcargo] #214855
02/10/09 12:56 PM
02/10/09 12:56 PM
nc
E
E
nc
So what you think
We just put 2 leafs back in down from 4 & have around 2" of down travel now thats not too stiff, than it starts to bind and stiffen up , with the 4 leafs you could not move the back of the truck down at all, I am thinking of pulling the last spring and trying it with only the main spring ,gota check rules
Page 3 of 3 1 2 3
