How much are my small headers killing my performance
#2148281
09/05/16 09:16 PM
09/05/16 09:16 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
I have a 900 horsepower W7 small block with 1 7/8 headers on it. I put more gear in the rear end. (4.88 to 5.38) and more converter doesn't seem to make much difference on the performance. I'm thinking the headers are holding this thing back big time..runs 9.20s in 3000 da air @ 2800 lbs ???????????
Re: How much are my small headers killing my performance
[Re: Plymouth340]
#2148297
09/05/16 09:26 PM
09/05/16 09:26 PM
hustlin hoosier
We have tried about everything possible with headers and never found over a few hundredths going from what we thought was a great set of headers to what we thought was the worst set of headers. I hope you have better luck chasing et with we exhaust than we did.
[Re: camastomcat]
#2148346
09/05/16 10:21 PM
09/05/16 10:21 PM
Plymouth340
CEDAR RAPIDS
that's just it. I think they are considering the step headers that were on it when the previous owner was running it.. Converter is 7000 stall and motor makes peak hp at 9000
[Re: Plymouth340]
#2148764
09/06/16 01:27 PM
09/06/16 01:27 PM
Posts: 4,206 New York
polyspheric
New York
Tried shortening the collector?
Boffin Emeritus
[Re: Plymouth340]
#2148813
09/06/16 02:32 PM
09/06/16 02:32 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's "900hp", what headers were on it when it made 900hp?
2800 lbs, 148mph shows 700hp on the moroso chart. Figuring 10% loss for air quality, parasitic losses, etc, you're still off over 100hp. I don't know if the headers would be worth that kind of power.
[Re: Plymouth340]
#2148916
09/06/16 04:25 PM
09/06/16 04:25 PM
fast68plymouth
So. Burlington, Vt.
At seasons end...... Might be worth a trip to the dyno and see just how much difference in power there is between the headers......before going through the effort of fitting them to the car.
[Re: camastomcat]
#2149020
09/06/16 06:44 PM
09/06/16 06:44 PM
fast68plymouth
So. Burlington, Vt.
Isn't Dwayne Porter a small block guy? Mmmmmmmm, not particularly. Never even laid my eyes on a W7 head in person.
[Re: Plymouth340]
#2149023
09/06/16 06:48 PM
09/06/16 06:48 PM
fast68plymouth
So. Burlington, Vt.
I need to talk to someone about it that knows more than me that's why I'm asking. Unless someone has tested a motor combo that's very close to yours with both sizes of headers you're talking about, and they're willing to share that info, you might have to test if for yourself to find out exactly what the answer is....... On your motor. 100+ hp seems like a stretch for a header swap to me....... But that's what the dyno is for. To provide answers to those questions.
[Re: Plymouth340]
#2149027
09/06/16 06:58 PM
09/06/16 06:58 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
If max hp is at 9000rpm why are you shifting at 8700?
I don't know a thing about W7 engines but 900hp sounds a little optomistic.
[Re: Plymouth340]
#2149270
09/06/16 11:55 PM
09/06/16 11:55 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
My guess is the super stock guy probably wasn't using those headers unless they made more power than anything else he has tried. I would try and make them work and report back.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2149287
09/07/16 12:05 AM
09/07/16 12:05 AM
Plymouth340
CEDAR RAPIDS
My guess is the super stock guy probably wasn't using those headers unless they made more power than anything else he has tried. I would try and make them work and report back. I think that's going to be the plan for now
[Re: Plymouth340]
#2149301
09/07/16 12:32 AM
09/07/16 12:32 AM
B3422W5
Portage,michigan
Several years back Brian( IMM engines) who posts on here ran two different sets of headers on I believe a stroker W2 motor. Headmans and TTI headers as memory serves me. There was a 30 or 40 horse difference between them
[Re: B3422W5]
#2149315
09/07/16 12:58 AM
09/07/16 12:58 AM
Plymouth340
CEDAR RAPIDS
Several years back Brian( IMM engines) who posts on here ran two different sets of headers on I believe a stroker W2 motor. Headmans and TTI headers as memory serves me. There was a 30 or 40 horse difference between them I wonder if there was a difference in diameter or length or what?
[Re: B3422W5]
#2149317
09/07/16 01:00 AM
09/07/16 01:00 AM
Posts: 20,161 PA.
pittsburghracer
"Little"John
"Little"John
PA.
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues
[Re: Plymouth340]
#2149585
09/07/16 01:46 PM
09/07/16 01:46 PM
fast68plymouth
So. Burlington, Vt.
To be running w7 heads in a super stock car, it would have to be one of the modified classes. The whole car was likely set up around that engine package, and I'm sure part of what the op is seeing is that a class car is often a better, more sophisticated overall "package" than a typical bracket car.
Take a stock eliminator motor out of a good running stocker package and stick it in a similar bracket car and I doubt the ET's would even be close.
Another question I would have is, how close to 900hp was the performance of the car the motor came out of? Did the ET/mph/weight show it to be 900hp?
[Re: Plymouth340]
#2150217
09/08/16 09:36 AM
09/08/16 09:36 AM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Another thought; an SS racer will kill for .02 ET. If he was running the headers that came were in the car he raced, They are probably as good as it gets, but might not show a lot of improvement. The best answer is try it and see. Be ready to tune for them, and find out EXACTLY what stall you have. I was fooled for years because I went by a tach. I am no small block guy, but hear they are sensitive to converters.
[Re: gregsdart]
#2150392
09/08/16 03:01 PM
09/08/16 03:01 PM
Plymouth340
CEDAR RAPIDS
Another thought; an SS racer will kill for .02 ET. If he was running the headers that came were in the car he raced, They are probably as good as it gets, but might not show a lot of improvement. The best answer is try it and see. Be ready to tune for them, and find out EXACTLY what stall you have. I was fooled for years because I went by a tach. I am no small block guy, but hear they are sensitive to converters. Yes one thing at a time I will put these headers on and see what happens. I had my converter stall raised from 6500 to 7000 that was all they could get out of my 8 inch converter. 60 footed a couple hundreds better but the ET remain the same
[Re: fast68plymouth]
#2150394
09/08/16 03:07 PM
09/08/16 03:07 PM
Plymouth340
CEDAR RAPIDS
Another question I would have is, how close to 900hp was the performance of the car the motor came out of? Did the ET/mph/weight show it to be 900hp? Yes his car was probably a whole lot better than mine being a super stock car. But what I really want to know is are my headers killing my motor a tremendous amount I'm going to find out over the winter
[Re: Plymouth340]
#2150437
09/08/16 04:42 PM
09/08/16 04:42 PM
fast68plymouth
So. Burlington, Vt.
What did the car the motor came out of weigh, and what was the speed?
IMO not a converter builder, but it seems to me that in order for an 8" converter to be loosened up enough to stall 7000rpm behind a motor with less than 600ft/lbs, it would lose some effeciency in the process.
[Re: Plymouth340]
#2150576
09/08/16 07:50 PM
09/08/16 07:50 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO
[Re: cudaman1969]
#2150645
09/08/16 09:30 PM
09/08/16 09:30 PM
Plymouth340
CEDAR RAPIDS
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference.
[Re: Plymouth340]
#2150663
09/08/16 10:05 PM
09/08/16 10:05 PM
cudaman1969
fredericksburg,va
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference. I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it.
[Re: cudaman1969]
#2150735
09/08/16 11:28 PM
09/08/16 11:28 PM
Plymouth340
CEDAR RAPIDS
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference. I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it. 153 mph @ 3280lbs this motor is legit it has the best of everything on it
[Re: slantzilla]
#2150801
09/09/16 01:06 AM
09/09/16 01:06 AM
Plymouth340
CEDAR RAPIDS
Are you runing the same converter, trans gearing, and rear gear he did? no,no,no all I'm wondering is if these 1 7/8 headers I'm using are killing my performance and if it would be worth the work to make the larger step headers work !!!
[Re: Plymouth340]
#2150868
09/09/16 08:51 AM
09/09/16 08:51 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes.
[image][/image]
[Re: Plymouth340]
#2150966
09/09/16 12:38 PM
09/09/16 12:38 PM
fast68plymouth
So. Burlington, Vt.
153 mph @ 3280lbs this motor is legit it has the best of everything on it The moroso chart shows that to be pretty much right on 900hp.
[Re: sgcuda]
#2151083
09/09/16 03:01 PM
09/09/16 03:01 PM
Plymouth340
CEDAR RAPIDS
It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes. Yes I think it will be worth the effort. I've never built headers before but to make these fit shouldn't be that bad I have a tube chassis car there's lots of room. And my time is free
#2151086
09/09/16 03:03 PM
09/09/16 03:03 PM
Plymouth340
CEDAR RAPIDS
153 mph @ 3280lbs this motor is legit it has the best of everything on it The moroso chart shows that to be pretty much right on 900hp. Yes the power is there. Just seems like something's holding this motor back. I've tried a lot of things and nothing really seems to make much difference so this is my next step
[Re: Plymouth340]
#2151216
09/09/16 06:54 PM
09/09/16 06:54 PM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
It will be interesting to see if your headers are killing 150 horse.
[Re: Alchemi]
#2151799
09/10/16 08:10 PM
09/10/16 08:10 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
All that header beat up test did was prove that the wrong headers were on the motor to start with.... You need to watch the follow up video. TL/DR answer, no they were the best size.
#2151875
09/10/16 10:07 PM
09/10/16 10:07 PM
BradH
At seasons end...... Might be worth a trip to the dyno and see just how much difference in power there is between the headers......before going through the effort of fitting them to the car. x2 Not only would you find out what the other headers are worth, it could provide more data to help with converter setup.
[Re: Plymouth340]
#2152381
09/11/16 02:56 PM
09/11/16 02:56 PM
Posts: 30,997 Oregon
AndyF
I did a header test on my 470 engine between 2" dyno headers and 1 3/4 stepped to 1 7/8 dyno headers. At 6800 rpm the 2" headers were 10 ft-lbs better.
[Re: Plymouth340]
#2152422
09/11/16 04:05 PM
09/11/16 04:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Damn, I'm not so upset with having 1.75 TTI's on my 420 G3 anymore.
Mopar to the bone!!!
[Re: pittsburghracer]
#2542525
08/28/18 02:58 PM
08/28/18 02:58 PM
Plymouth340
CEDAR RAPIDS
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet
[Re: justinp61]
#2542663
08/28/18 07:05 PM
08/28/18 07:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your not gonna see a 100hp difference from the set you have on the car to the ones that were on it.. I was running a W-9 with step headers (1 7/8-2-2 1/8.. if your conv stalls at 7000 it is real close I stalled at 5600 and it was a bit low.. I shifted at 8200 rpm.. it didnt make any more power when shifted at higher rpms.. I went up to 9400 and dint do a damn thing
[Re: Plymouth340]
#2542989
08/29/18 01:03 PM
08/29/18 01:03 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet What carb(s) are you running............
[Re: Plymouth340]
#2543006
08/29/18 01:41 PM
08/29/18 01:41 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
FWIW the smallblock in the heads up car made over 1000 with a set of 1 7/8" 20 long primary headers on the dyno. Headers on the car are 1 7/8 to 2 to 2 /18". Car ran 8.0's last year at 2800.
[Re: Plymouth340]
#2543019
08/29/18 01:59 PM
08/29/18 01:59 PM
Posts: 20,161 PA.
pittsburghracer
"Little"John
"Little"John
PA.
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet Very nice!!!!!!!
[Re: Al_Alguire]
#2543060
08/29/18 03:03 PM
08/29/18 03:03 PM
Plymouth340
CEDAR RAPIDS
FWIW the smallblock in the heads up car made over 1000 with a set of 1 7/8" 20 long primary headers on the dyno. Headers on the car are 1 7/8 to 2 to 2 /18". Car ran 8.0's last year at 2800. had some headers built...1 7/8-2 1/8-2 1/4..didnt see much performance diff..converter made all the diff
[Re: Thumperdart]
#2543062
08/29/18 03:04 PM
08/29/18 03:04 PM
Plymouth340
CEDAR RAPIDS
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues Well I finally put in a 7 inch converter and it picked up all most 2 tenths..9.07 @ 149 in 4000 da air..that was the ticket and I haven't tried leaving at higher rpm yet or a little more jet What carb(s) are you running............ one 1200 cfm
[Re: Plymouth340]
#2543394
08/30/18 12:27 PM
08/30/18 12:27 PM
gregsdart
I agree on the horsepower being in the 700 range with current setup,given a decent chassis. First off, you say peak power is 9,000 and you shift at 8700? Peak torque is 7200 and stall is 7,000? My deal makes peak power at 6900, and shift at 7450 and 2/3 at 7300, stall is 6200, but peak torque is 5,000! I dynoed the motor and it said 847 hp, car weighs 3065, i use 2078 Goodyear slicks that weigh 41 lbs each, and the car went 8.900 at 2100 da. The point of all this info is if ypur tq and hp peaks are what you say, the stall and shift points may be a big part of the problem. Too low. Its dyno time! Get the real dope on the motor and go from there.
