Re: How much are my small headers killing my performance
[Re: Plymouth340]
#2149027
09/06/16 06:58 PM
09/06/16 06:58 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
If max hp is at 9000rpm why are you shifting at 8700?
I don't know a thing about W7 engines but 900hp sounds a little optomistic.
[Re: Plymouth340]
#2149270
09/06/16 11:55 PM
09/06/16 11:55 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
My guess is the super stock guy probably wasn't using those headers unless they made more power than anything else he has tried. I would try and make them work and report back.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2149287
09/07/16 12:05 AM
09/07/16 12:05 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
My guess is the super stock guy probably wasn't using those headers unless they made more power than anything else he has tried. I would try and make them work and report back. I think that's going to be the plan for now
[Re: Plymouth340]
#2149301
09/07/16 12:32 AM
09/07/16 12:32 AM
B3422W5
Portage,michigan
Several years back Brian( IMM engines) who posts on here ran two different sets of headers on I believe a stroker W2 motor. Headmans and TTI headers as memory serves me. There was a 30 or 40 horse difference between them
[Re: B3422W5]
#2149315
09/07/16 12:58 AM
09/07/16 12:58 AM
Plymouth340
CEDAR RAPIDS
Several years back Brian( IMM engines) who posts on here ran two different sets of headers on I believe a stroker W2 motor. Headmans and TTI headers as memory serves me. There was a 30 or 40 horse difference between them I wonder if there was a difference in diameter or length or what?
[Re: B3422W5]
#2149317
09/07/16 01:00 AM
09/07/16 01:00 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
From everything I've read and heard about this engine combo I would lean towards the converter not being the right stall. That seems to be the biggest issues
[Re: Plymouth340]
#2149585
09/07/16 01:46 PM
09/07/16 01:46 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
To be running w7 heads in a super stock car, it would have to be one of the modified classes. The whole car was likely set up around that engine package, and I'm sure part of what the op is seeing is that a class car is often a better, more sophisticated overall "package" than a typical bracket car.
Take a stock eliminator motor out of a good running stocker package and stick it in a similar bracket car and I doubt the ET's would even be close.
Another question I would have is, how close to 900hp was the performance of the car the motor came out of? Did the ET/mph/weight show it to be 900hp?
[Re: Plymouth340]
#2150217
09/08/16 09:36 AM
09/08/16 09:36 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Another thought; an SS racer will kill for .02 ET. If he was running the headers that came were in the car he raced, They are probably as good as it gets, but might not show a lot of improvement. The best answer is try it and see. Be ready to tune for them, and find out EXACTLY what stall you have. I was fooled for years because I went by a tach. I am no small block guy, but hear they are sensitive to converters.
[Re: gregsdart]
#2150392
09/08/16 03:01 PM
09/08/16 03:01 PM
Plymouth340
CEDAR RAPIDS
Another thought; an SS racer will kill for .02 ET. If he was running the headers that came were in the car he raced, They are probably as good as it gets, but might not show a lot of improvement. The best answer is try it and see. Be ready to tune for them, and find out EXACTLY what stall you have. I was fooled for years because I went by a tach. I am no small block guy, but hear they are sensitive to converters. Yes one thing at a time I will put these headers on and see what happens. I had my converter stall raised from 6500 to 7000 that was all they could get out of my 8 inch converter. 60 footed a couple hundreds better but the ET remain the same
[Re: fast68plymouth]
#2150394
09/08/16 03:07 PM
09/08/16 03:07 PM
Plymouth340
CEDAR RAPIDS
Another question I would have is, how close to 900hp was the performance of the car the motor came out of? Did the ET/mph/weight show it to be 900hp? Yes his car was probably a whole lot better than mine being a super stock car. But what I really want to know is are my headers killing my motor a tremendous amount I'm going to find out over the winter
[Re: Plymouth340]
#2150437
09/08/16 04:42 PM
09/08/16 04:42 PM
fast68plymouth
So. Burlington, Vt.
What did the car the motor came out of weigh, and what was the speed?
IMO not a converter builder, but it seems to me that in order for an 8" converter to be loosened up enough to stall 7000rpm behind a motor with less than 600ft/lbs, it would lose some effeciency in the process.
[Re: Plymouth340]
#2150576
09/08/16 07:50 PM
09/08/16 07:50 PM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO
[Re: cudaman1969]
#2150645
09/08/16 09:30 PM
09/08/16 09:30 PM
Plymouth340
CEDAR RAPIDS
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference.
[Re: Plymouth340]
#2150663
09/08/16 10:05 PM
09/08/16 10:05 PM
cudaman1969
fredericksburg,va
I'll throw this out there, not sure if it means much. Read about a test some engine builder did on a small block Chevy, on the dyno, with the results of dinging headers, if it lost power. They went so far as to almost flatten them completely and saw no power loss, maybe 4 or 5 hp tops, they where dumbfounded? You might see a change in a poorly designed set over a top of the line set, but not the gains you're looking for, IMO That could be true. But what was the horsepower level of that motor? I would think this 900 horsepower motor turning 8,700 rpm it would make a bit of difference. I would be skeptical of it being 900 hp unless I was there when they dynoed it. Did he say what mph the other car was going? The header banging was a u-tube video. I dought they could fake it.
