Re: Torque Strap With Mighty Mounts?
[Re: 71rm23]
#2146925
09/03/16 07:20 PM
09/03/16 07:20 PM
Posts: 3,344 Central TX
roe
Central TX
I made my own. There's a thread on here you can find with the Google search feature that walks you through using two grade 8 bolts through the drivers side motor mount. Worked like a charm. It's basically a cheaper and stronger version of the Schumacher mounts. I also used a turnbuckle on the passenger side head to the k-frame. Way less motor rock which meant more power through the drivetrain and to the wheels.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: patosmith]
#2146926
09/03/16 07:22 PM
09/03/16 07:22 PM
Posts: 5,439 So Cal
Sinitro
So Cal
A torque strap is a necessity if the car is a 4 speed.. Just my $0.02...
[Re: roe]
#2147037
09/03/16 10:43 PM
09/03/16 10:43 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Mighty Mount or torque strap. You do not need both. I also used a turnbuckle on the passenger side head to the k-frame. Roe, what is this for reverse?
[Re: Magnum]
#2147065
09/03/16 11:30 PM
09/03/16 11:30 PM
roe
Central TX
Mighty Mount or torque strap. You do not need both. I also used a turnbuckle on the passenger side head to the k-frame. Roe, what is this for reverse? It still works on the same premise, just takes some of the load so its not all on the the driver side. Motor tries to compress against the turnbuckle on the passenger side at the same time it's pulling against the "torque strap" on driver side. Both prevent the motor from trying to rotate towards the passenger side. 2 are stronger than 1. And like mentioned it spreads the force out instead of all on the drivers side. roe edit: same idea as solid mounts on both sides but without the vibrations
[Re: patosmith]
#2147195
09/04/16 10:25 AM
09/04/16 10:25 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I used Mighty Mounts when I installed the 440 in my 4 speed Challenger. I took the car for a test ride with the hood off and during hard acceleration the engine moved/torqued too much for my liking so I made a torque strap from a turnbuckle and a small section of chain. I have it adjusted so it only gets tight if the engine really move a good amount. It has worked fine for 6 years now. The Mighty Mounts seem like quality products and I'm probably just being over cautious but the torque strap was cheap and easy to install.
[Re: patosmith]
#2147915
09/05/16 12:30 PM
09/05/16 12:30 PM
Posts: 293 Spanaway, Washington State
patosmith
Thanks everyone for your comments. I probably should have told you more about the car. I am running a 727 and 10 inch Mickey Thompson's in the back. Right now I have the stock 8 3/4 rearend with the Calvert setup. We'll see how long the rear lasts. The car will be driven to local shows but I will also drag race in the car club challenge with our club.
I think the mounts would be fine by themselves but I think I will add a strap just for peace of mind. Thanks again.
