68 Cuda Trunk Extension Availability #214675
02/05/09 10:06 AM
02/05/09 10:06 AM
1.5 hours SE of Pittsburg, Pa
geno440 Offline OP
geno440  Offline OP
Has anyone started reproducing these for a cuda yet? Exact fit?
I bought a set off of Auto Body Specialists last summer for 67-69 a body. They said they would work with slight modifications. I can't see how they would work without looking bad.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: 68 Cuda Trunk Extension Availability [Re: geno440] #214676
02/05/09 10:14 AM
02/05/09 10:14 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Nope. I also bought the dart ones and personally think the suggestion that they will work is full of bunk. They are not even the right width in the trunk area. At least it is a start but they will require a lot of modification. You would think these would be repopped. My guess is at least 100k cars were built(don't have the numbers on hand) and this is a part that needs to be replaced on almost every car. But wait, I guess they would rather make another grill for a high seller like the 68RR.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: 68 Cuda Trunk Extension Availability [Re: klunick] #214677
02/05/09 10:32 AM
02/05/09 10:32 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
We need those and full quarters badly.
Re: 68 Cuda Trunk Extension Availability [Re: geno440] #214678
02/05/09 10:38 AM
02/05/09 10:38 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
If the flat part of the trunk extention is in good shape and it's the vertical piece that needs replacing you can buy a trunk extention for a 68 Dart but the back radius will need to be slightly modified but not a big deal. I did this on my 68 fastback and it worked great. However, it will not work if you need to replace the entire extention.
