Re: 440 direct connection distributor
[Re: Hangtowner]
#2144775
08/31/16 06:57 PM
08/31/16 06:57 PM
RapidRobert
no info on specs but you might turn the can CCW 2 turns with a 3/32 allen wrench (I'm assuming this is part throttle pinging climbing a hill, disregared if WOT), otherwise I would note your initial and your total and at what RPM it maxes out at & likely will need to first loosen/turn the housing to be able to see what springs are in there (OE combo is light/heavy with elongated loop on one end). Older (non Mallory) I am assuming.
[Re: lewtot184]
#2145226
09/01/16 10:31 AM
09/01/16 10:31 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
'432 should have a green/white primary spring, pinkish-blue heavy secondary spring, 13 degree plate and 9 degree vacuum advance. total centrifugal advance comes in around 2800rpm. 13 degree plate which means it has 26 degrees of mechanical advance . Hang what is your initial timing set at ?
[Re: Hangtowner]
#2146130
09/02/16 01:46 PM
09/02/16 01:46 PM
JohnRR
Yes, I will turn the screw in the can. Years ago when I got it 432, I didn't know about the screw in the can. All that will do is delay or quicken vac advance , it does nothing to limit it.
[Re: Hangtowner]
#2146289
09/02/16 05:52 PM
09/02/16 05:52 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
naw, you got to get in there and put a spot weld down and file to get the mec. advance where you want. last one I did was 5 degrees total, all in, big ass cam.
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2146369
09/02/16 07:58 PM
09/02/16 07:58 PM
RapidRobert
the FBO $22 plate is the best deal going for altering mech adv & has slots for 10-12-14-16-18 degrees
[Re: Hangtowner]
#2146479
09/02/16 11:20 PM
09/02/16 11:20 PM
RapidRobert
My initial timing is 5 degrees. It is too hard to start at 8 or 10. This is 8.3 CR and not a Magnum cam. we're missing something. with those numbers no way should it be cranky (just from the DCR) being generated
[Re: Hangtowner]
#2146821
09/03/16 03:32 PM
09/03/16 03:32 PM
RapidRobert
I would suggest (1) checking true TDC (2) see what your cranking compression is
[Re: Hangtowner]
#2146826
09/03/16 03:46 PM
09/03/16 03:46 PM
Posts: 2,094 central texas
krautrock
central texas
My initial timing is 5 degrees. It is too hard to start at 8 or 10. This is 8.3 CR and not a Magnum cam. with 8.3 compression this thing should not be hard to start at 10* advance, nor should it be pinging. i would check that the timing mark on the balancer is correct.
[Re: Hangtowner]
#2153274
09/12/16 08:29 PM
09/12/16 08:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I don't think I would trust the whistle method for finding TDC.
I would use a stop to find it.
[Re: Hangtowner]
#2153696
09/13/16 02:08 PM
09/13/16 02:08 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Just put a stiff copper wire in there. It will top out and start moving down again once top dead center is achieved. Wont hurt a thing.
I have mechanical Aptitude. I can screw up anything.
[Re: Hangtowner]
#2153844
09/13/16 05:44 PM
09/13/16 05:44 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Or stick your pinky in the spark plug hole. It will be at TDC twice (firing & top of exhaust stroke) per crank rotation.
To find the exact TDC, you really need a "stop" which won't damage your piston if you're turning the engine by hand.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
