440 direct connection distributor #2144757
08/31/16 06:45 PM
08/31/16 06:45 PM
Hangtowner Offline OP
I have a distributor part number 3690432 I bought about 1996. It gave me pinging at 70mph climbing a hill. I thought I took it out and put in the original (74 Jensen Interceptor). Now I look at the tag on the one in the car and it says 3690432 and the distributor in the old box has no tag. I don't find the curve specs for it in my old Motor Manual like a 3755518 (which I have a couple of) or in the Direct Connection book. Is the only way to find the spec to dissasemble and look at the springs?
Re: 440 direct connection distributor [Re: Hangtowner] #2144775
08/31/16 06:57 PM
08/31/16 06:57 PM
no info on specs but you might turn the can CCW 2 turns with a 3/32 allen wrench (I'm assuming this is part throttle pinging climbing a hill, disregared if WOT), otherwise I would note your initial and your total and at what RPM it maxes out at & likely will need to first loosen/turn the housing to be able to see what springs are in there (OE combo is light/heavy with elongated loop on one end). Older (non Mallory) I am assuming.
Re: 440 direct connection distributor [Re: Hangtowner] #2144830
08/31/16 07:50 PM
08/31/16 07:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
'432 should have a green/white primary spring, pinkish-blue heavy secondary spring, 13 degree plate and 9 degree vacuum advance. total centrifugal advance comes in around 2800rpm.
Re: 440 direct connection distributor [Re: lewtot184] #2145226
09/01/16 10:31 AM
09/01/16 10:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
13 degree plate which means it has 26 degrees of mechanical advance .
Hang what is your initial timing set at ?
Re: 440 direct connection distributor [Re: JohnRR] #2145707
09/01/16 09:41 PM
09/01/16 09:41 PM
My initial timing is 5 degrees. It is too hard to start at 8 or 10. This is 8.3 CR and not a Magnum cam.
Re: 440 direct connection distributor [Re: lewtot184] #2145710
09/01/16 09:42 PM
09/01/16 09:42 PM
Thanks for the specs. I can see the one in the box has a blue heavy spring.
Re: 440 direct connection distributor [Re: Hangtowner] #2145711
09/01/16 09:44 PM
09/01/16 09:44 PM
Yes, I will turn the screw in the can. Years ago when I got it 432, I didn't know about the screw in the can.
Re: 440 direct connection distributor [Re: Hangtowner] #2146130
09/02/16 01:46 PM
09/02/16 01:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
All that will do is delay or quicken vac advance , it does nothing to limit it.
Re: 440 direct connection distributor [Re: Hangtowner] #2146289
09/02/16 05:52 PM
09/02/16 05:52 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
naw, you got to get in there and put a spot weld down and file to get the mec. advance where you want. last one I did was 5 degrees total, all in, big ass cam.
Have a great day
Iowan
"obsolete is neat"
Re: 440 direct connection distributor [Re: Iowan] #2146369
09/02/16 07:58 PM
09/02/16 07:58 PM
the FBO $22 plate is the best deal going for altering mech adv & has slots for 10-12-14-16-18 degrees
Re: 440 direct connection distributor [Re: Hangtowner] #2146394
09/02/16 08:48 PM
09/02/16 08:48 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
no 5 degrees total?
Have a great day
Iowan
"obsolete is neat"
Re: 440 direct connection distributor [Re: Hangtowner] #2146479
09/02/16 11:20 PM
09/02/16 11:20 PM
we're missing something. with those numbers no way should it be cranky (just from the DCR) being generated
Re: 440 direct connection distributor [Re: Hangtowner] #2146793
09/03/16 02:07 PM
09/03/16 02:07 PM
I have the FBO plate in my tool box. When I had this distributor in the original engine (Magnum cam) I could set the initial to 10 degrees, but not with this engine. So I figure the main difference is the cam, but then this engine is from a junk yard for $200. Maybe it is no longer 8.3 (1977 is stamped on the block)?
Re: 440 direct connection distributor [Re: Hangtowner] #2146821
09/03/16 03:32 PM
09/03/16 03:32 PM
I would suggest (1) checking true TDC (2) see what your cranking compression is
Re: 440 direct connection distributor [Re: Hangtowner] #2146826
09/03/16 03:46 PM
09/03/16 03:46 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
with 8.3 compression this thing should not be hard to start at 10* advance, nor should it be pinging.
i would check that the timing mark on the balancer is correct.
Re: 440 direct connection distributor [Re: Hangtowner] #2153225
09/12/16 06:52 PM
09/12/16 06:52 PM
Good idea. I have just done a sort of quick check using a whistle on a compression tester and bumping the starter. Only #1 plug was removed. With the whistle method, TDC is 1 3/4 inches below the timing cover grid which has its lowest gradation as 20. I repeated it 3 times. The timing cover is marked 0, 10, 20. The engine block says 8T440 E and below it is 8 25. Do I need to take all the plugs out (real pain with these headers in a Interceptor) and repeat the TDC check or is this enough to tell me there is a real marking or parts missmatch problem?
Thanks guys.
Re: 440 direct connection distributor [Re: Hangtowner] #2153274
09/12/16 08:29 PM
09/12/16 08:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't think I would trust the whistle method for finding TDC.
I would use a stop to find it.
Don't be the exception.
Re: 440 direct connection distributor [Re: Hangtowner] #2153678
09/13/16 01:35 PM
09/13/16 01:35 PM
Can I buy a stop or do I have to make something. I wouldn't want to dent the piston.
Re: 440 direct connection distributor [Re: Hangtowner] #2153696
09/13/16 02:08 PM
09/13/16 02:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just put a stiff copper wire in there.
It will top out and start moving down again once top dead center is achieved.
Wont hurt a thing.
I have mechanical Aptitude.
I can screw up anything.
Re: 440 direct connection distributor [Re: Hangtowner] #2153844
09/13/16 05:44 PM
09/13/16 05:44 PM
Chicago
PurpleBeeper Offline
Chicago
Or stick your pinky in the spark plug hole. It will be at TDC twice (firing & top of exhaust stroke) per crank rotation.
To find the exact TDC, you really need a "stop" which won't damage your piston if you're turning the engine by hand.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
