Adjustable rockers for a hydraulic cam *DELETED* #214363
02/04/09 10:48 PM
02/04/09 10:48 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Post deleted by Dodge
Stand behind your word
Re: Adjustable rockers for a hydraulic cam [Re: Dodge] #214364
02/04/09 11:10 PM
02/04/09 11:10 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
0.030 preload which is 1/2-3/4 turn past zero lash if i remember right.
Re: Adjustable rockers for a hydraulic cam [Re: dirtybee] #214365
02/04/09 11:12 PM
02/04/09 11:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If they were from a sold cam you will need shorter pushrods
Re: Adjustable rockers for a hydraulic cam [Re: Dodge] #214366
02/04/09 11:18 PM
02/04/09 11:18 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
When I bought the Cuda, the engine was rebuilt and not in the car. It had a 292/509 cam and these rockers it was a real dog. I put the car away for the last 6 years until last summer. I changed a bunch of things including the cam. I put a Comp Cam XE274H in along with a RPM intake and 750 eddy carb. Much better. I want to use the rockers on my 70 charger RT when I rebuild the engine.
Re: Adjustable rockers for a hydraulic cam [Re: Dodge] #214367
02/05/09 12:31 AM
02/05/09 12:31 AM
calif
cupcake Offline
cupcake  Offline
calif
how u like that cam i hated it made the car smell like a gas pump
Re: Adjustable rockers for a hydraulic cam [Re: Dodge] #214368
02/05/09 11:31 AM
02/05/09 11:31 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Here is a link to our site with some instructions that might help you.
http://hughesengines.com/Upload/productInstructions/Valveadjustmentprocedure.pdf
Normally for street driving you will want about .040" preload.
Kevin @ Hughes
