Re: SLIMMING DOWN A TRW SLUG [Re: A/MP] #2142074
08/27/16 07:23 PM
08/27/16 07:23 PM
Make sure and get a tool steel wrist pin that will live with your new build scope twocents
Re: SLIMMING DOWN A TRW SLUG [Re: A/MP] #2143089
08/29/16 12:31 PM
08/29/16 12:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By A/MP
My purpose of this post is that I want to try a turbo and make about 600 HP using parts that I have. Factory 360 crank is good for 600 HP. I have plenty of lighter H beam rods and 2-3 set of forged 360 pistons that I saved for some stock eliminator builds. The pistons are good for 8-8.5:1. I like the idea of using lighter wrist pins. That's an easy purchase. The less reciprocating weight that I have the easier I'll feel about the crank.
Info that probably should have been included in the first post ???
Re: SLIMMING DOWN A TRW SLUG [Re: A/MP] #2143153
08/29/16 02:26 PM
08/29/16 02:26 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I've done this on 2 different sets of pistons, both were the old trw speed pro heavy slugs. One 318 the other was a 340. I sure spent a lot of time researching and fiddling with them. I don't do this anymore. I probably got 100 grams out of each piston. I also added lite weight pins. I believe the pins were distorting some due to the weight of the pistons as there was some gaulding seen on the freshen ups. I even cut through the underside and had the pistons heli arced. Both engines lasted quite a while one broke a crank after about 600 passes the other broke a rod after about 400 passes. Both motors had reworked stock rods and I shifted them at about 7500.I laugh at myself now as I wouldn't think about doing this again. For the time I spent on them I could have bought a good set of pistons. But money was tight.
Re: SLIMMING DOWN A TRW SLUG [Re: DavidDean] #2143269
08/29/16 06:52 PM
08/29/16 06:52 PM
dogdays Offline
dogdays  Offline
Here's what makes this whole idea a bummer: 1 cubic inch of aluminum weighs 44.25 grams.
For a turbo build I'd run them stock and use a decent lighter rod. You can easily lose 100 grams from the rod.
I don't think you're going to have trouble with the crank if you keep the rpm down and don't detonate.
Make the wristpins too light and they start to deform. Tool steel deforms the same as mild steed. it just takes much more load to get it to change shape. Look for tapered wall pins or possibly research some other players and see what they do.
R.
