Anyone here install windshield ? #2141734
08/27/16 04:55 AM
08/27/16 04:55 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
We had the 71 charger painted. Windshield was out. Thought about doing my self (with help) can you use seal/rope from parts store? Any trick/tips making sure it don't leak?
Any brand better then others?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Anyone here install windshield ? [Re: toplescuda] #2141736
08/27/16 05:17 AM
08/27/16 05:17 AM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
I watched the guy replace the windshield in my (late model) truck.
He had an 18V cordless caulking gun & he used 3 tubes of black windshield sealant, ran a thick bead into the track, then 2 guys used suction cups to maneuver the windshield into place to press it down.
Probably not something I would try myself...
Re: Anyone here install windshield ? [Re: shocktrp] #2141920
08/27/16 03:16 PM
08/27/16 03:16 PM
I did my 66 & 65 dart & used the black urethane? the auto body supply shop sold me hardening the first time around & years later for the 65 they only offered the non hardening (not sure which is preferred). I used it on the black gasket as it contacts the metal frame channel then some in the groove in the gasket channel then set the WS in place into the gasket channel. you DO need 1 or 2 helpers. if using the hardening be SURE to wipe off any excess before it sets as it ain't going anywhere if you dont. it ain't difficult, just take your time/be meticulous & STOP & regroup if something dont feel or look right. you need all sides sealed to stop the water
Re: Anyone here install windshield ? [Re: toplescuda] #2141960
08/27/16 03:58 PM
08/27/16 03:58 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do your self a favor and get a professional to do the job. They will have it done in 30 minutes. If the windshield is not set correctly the trim will not go on. One idiot set my 71 with the rope stuff and I had to pay someone else to remove it and they used urethane and then the trim fit and no leaks.
Re: Anyone here install windshield ? [Re: 71birdJ68] #2141965
08/27/16 04:04 PM
08/27/16 04:04 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
That's kind of interesting as your car came stock with the "rope stuff"...
Re: Anyone here install windshield ? [Re: toplescuda] #2142004
08/27/16 05:02 PM
08/27/16 05:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It is pretty easy to do it yourself. Use the "rope stuff" not the urethane.
Re: Anyone here install windshield ? [Re: minivan] #2142036
08/27/16 06:21 PM
08/27/16 06:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think maybe 71 was when they started using urethane on some cars. The service manual says to use urethane.
Re: Anyone here install windshield ? [Re: 71birdJ68] #2142145
08/27/16 09:55 PM
08/27/16 09:55 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
74 is when it was federally mandated... I NEVER saw urethane in any car before that when I was doing auto glass in 75-81...
Re: Anyone here install windshield ? [Re: toplescuda] #2142148
08/27/16 10:05 PM
08/27/16 10:05 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
The car does not have a gasket that you use the rope trick to install
I was referring to the kind that comes in a roll. I just called it a rope sorry
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142151
08/27/16 10:15 PM
08/27/16 10:15 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep a roll of 3/8" Butyl tape. That is what the factory used. Not hard to do but then I do several front and rear windows a year. Never any leaks and one I did over 20 years ago is still holding strong.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Anyone here install windshield ? [Re: toplescuda] #2142152
08/27/16 10:16 PM
08/27/16 10:16 PM
moparmarks Offline
moparmarks  Offline
Be sure the trim clips are good or replaced before the glass goes in.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Anyone here install windshield ? [Re: toplescuda] #2142159
08/27/16 10:23 PM
08/27/16 10:23 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
That 3/8 stuff. Can get at parts store? Any brand stay away from?
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142161
08/27/16 10:25 PM
08/27/16 10:25 PM
moparmarks Offline
moparmarks  Offline
I use 3M about 25.00 at NAPA.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Anyone here install windshield ? [Re: toplescuda] #2142163
08/27/16 10:28 PM
08/27/16 10:28 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Thank you sir
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142164
08/27/16 10:29 PM
08/27/16 10:29 PM
moparmarks Offline
moparmarks  Offline
No worries.
Be sure to have the two little rubber spacer blocks at the bottom.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Anyone here install windshield ? [Re: toplescuda] #2142207
08/28/16 12:21 AM
08/28/16 12:21 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Are you reusing your old ws or a new one??
Re: Anyone here install windshield ? [Re: toplescuda] #2142224
08/28/16 12:48 AM
08/28/16 12:48 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Orignal windshield. Yeah I don't remember if still have the Lil rubber wedges that windshield sets on or not......let just say I don't. Where can I come up with those at?
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142242
08/28/16 01:12 AM
08/28/16 01:12 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I do them all the time, one of the easiest things you can do to a car. Hard part is stripping the old sealer out and fixing the rust in the channel. When the channel is all clean and painted you install new trim clips all around and straighten and polish the trim itself. Then carefully lay the new windshield in the cavity and see where it is centered, if you are using a helper show them how the windshield is oriented from side to side or take a cellphone photo of it (remember yourself as well), Now see what you need to space it top to bottom and you can cut some spacers out of rubber (old body bumpers for example) obviously the spacers go in the bottom, you can bond the spacers in if you want but I don't. Lay a blanket on the roof and throw the windshield up there.
Paint your pinchweld primer. Lay your ribbon down, make sure you get the thick stuff not the thin or the trim won't fit. Rolll down the door windows. Then get your helper on the other side. Grab the windshield with both hands, when you get it down to say 1 foot in front of the windshield opening put one hand through the sidewindow and support the glass on the inside and with your other hand holding it on the outside, have your helper do the same. Then tell your helper to bring it close to the opening and lined up properly but about 6 inches away from it. Then guide your lower corner in and gently place it correctly the first time. Just lightly place that lower corner and then go to the other side. Grab the windshield the same way and let the helper get out of the way (or let them place it if you trust them), then place it home. After that you pat it home all around the perimeter. The sealer will go black when it touches the glass and you"ll know it is sealed, it is hard to tell along the top with a shaded screen though. Total elapsed time, less than 30 minutes.
Sheldon
Sheldon
Re: Anyone here install windshield ? [Re: toplescuda] #2142247
08/28/16 01:20 AM
08/28/16 01:20 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
When had my cuda done. They dry fit it and took masking tape from glass to roof. Cut it across. Then when payed in for last time just lined up the tape
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142406
08/28/16 12:39 PM
08/28/16 12:39 PM
None
71rm23 Offline
71rm23  Offline
None
71 RR here. I don't have the rubber spacers (lost) and be interested on where to get them as well or ideas on what to use instead.
Also, on the butyl tape. Was there a 3/8" in the front and 5/16" for the rear?
